Results 1 to 6 of 6
    Jun 2019
    Connecticut
    Cool Issue with battery light on my 08 Spyder
    I have a 2008 Spyder. The low battery light keeps blinking. I’ve changed the voltage regulator. I’ve Changed the battery. Voltage tests show good voltage to the battery upon start up, idling and when giving it gas. The local Spyder dealership/repair shop can’t find anything. Does anyone have any idea?
    Jul 2010
    Las Vegas, NV
    The ground connection. From the battery to the frame. Check both ends. The frame end rarely gets tightened.
    Joe Meyer
    Bossier LoUiSiAna
    second opinion different dealer
    Apr 2017
    North Central Florida
    Quote Originally Posted by ScottlvsEva View Post
    What voltage readings exactly ?
    The circuit that runs the warning light might not have a good connection.......or has failed.
    Jun 2019
    Connecticut
    Thank you cptjam I will look into that. And I would like to thank you for your service as well.
    Default Bummer.....
    For sure check all connections... the voltage rectifier hopefully was bad though have found the culprit is usually the stator. You need to have that output checked as that will determine if you are getting the proper voltage to the battery. Not knowing more it is hard to say. Do you have battery problems like keeping charged etc. Have you had any electircal work done like lights, horn, LED's etc.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
