Results 1 to 13 of 13
Thread: Disc Brake Pin
    Mar 2019
    Pennsylvania
    Default Disc Brake Pin
    One thing that I have heard very little about is the need to put a pin in the rotor to stop the wheel from turning when taking off and putting on the wheel nuts. What are you all using as a pin? Am I incorrect or is there another method?
    Jan 2017
    Bavaria, Germany
    Watch this video, minute 11:11
    2016 F3-S Special Series , triple black
    Default Interesting....🤔
    Never have and have not heard this mentioned anywhere. Guess it would help line up the wheel and the lug bolts but never been much of a problem and that putting a pin in the rotor would be if you don't remember to remove it.....I will continue my way....
    Mar 2019
    Pennsylvania
    Not sure if I was clear enough. How do you keep the wheel and rotor from spinning while tightening the wheel nut to 220 ft/lbs.
    Jan 2017
    Bavaria, Germany
    You can see the fixation of the wheel in the video at minute 11:11. Just watch it.
    Mar 2019
    Pennsylvania
    Sir, I did watch the video, twice. It doesn’t show how to stop wheel and rotor from turning while tightening to torque spec.
    Apr 2019
    Kansas
    Use an Allen Wrench as stated in the manual on page 95 to put through the hole for wheel removal. Lots of good information on the owners manual.
    3. Turn the handlebar and lock the
    wheel hub with a locking device
    (such as a long Allen key or a tempered
    steel rod).
    _______________
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by poconoscooter1 View Post
    At the 11:10 mark of the video.
    On the inside side of the wheel there are two holes that line up with a notch in the hub. You have to insert a shat of some sort through the notch and the holes to keep everything from rotating while the nut is being torques on or off.
    In the video, they used what looks like an allen wrench.
    Mar 2019
    Pennsylvania
    Thank you for this information.
    Feb 2019
    England
    Hi poconoscooter ref rotor pin I cut a long drift round bar or a long Allen key which just fit n to and through the hole (in handbook ) the snug fit the better. Regards Nico 75
    Mar 2019
    Pennsylvania
    Thank you Nico! The video confused me as I saw the rotor moving with the pin in. I now understand how it works. I will take your advise and will probably use a drift or round bar.
    Apr 2019
    Kansas
    Might be able to accomplish the same thing by torquing with the bike on the ground, it may still spin though cranking that thing down to 221 ft. lbs.
    Feb 2019
    England
    Hi Tommy bar which is a NICE fit in holes , just long enough to pass through I cut a Tommy bar to the size I wanted regards Nico 75
