Results 1 to 10 of 10
    Jun 2019
    New Jersey
    Default 2018 RTL outdoor cover pools water
    Hello,
    I am new to the forum and new to the Spyder family. I am on the road with my new Spyder and I cover it every night. I have the Ultraguard cover and it seems to fit well and serve its purpose. My question is the cover pools water in the rain between the front of the bike which is elevated and the rear trunk which is again higher than the area over the seat. Has anyone found a way to eliminate this? I am not sure that any other cover could eliminate this problem. After a very rainy night there was quite a bit of water pooled up stressing the cover especially between the antenna and the front grips and windshield area. I did a quick search but found nothing on this issue.
    Apr 2017
    North Central Florida
    Very common problem with almost all covers, to some degree.
    Adding some additional tie straps that go UNDER the bike so you can draw the cover tight should help a lot but likely won't eliminate it completely.
    Note: just cutting a hole in the cover to attach extra straps isn't good enough.......as windy conditions will tear out the hole rather quickly.
    Jul 2010
    Las Vegas, NV
    Get a windshield shade, the kind that pops open and is collapsed with a ring. Put on cover, open shade, sit it on the seat: no more low spot, no more puddle. Fits in saddlebag.
    Joe Meyer
    Bossier loUiSiAna
    Quote Originally Posted by cptjam View Post
    that or few bungees hooked on bottom of the front side of windshield, run up & over like clothesline to a loop around trunk. Bungee placements experimentation may be required. But that will provide support across the middle when you cover & bungees can wad up in small or strap down additional stuff you may want to carry
    T r * * LED:foam grip covers, Tricrings, FenderZ &brake light strips,
    wide vue mirrors
    BRP trailer hitch & 622 trailer (with its own list: Spyderpops Lighted Rear Bumpskid, LineX protection on sides, led trim lighting amber front& red rear, stand& tongue handle)THX Cruzr Joe!
    (pics in album)
    Active Member FalconAF's Avatar
    Mar 2019
    North Las Vegas, NV, Third Rock From The Sun
    Joe, do you have a link to the "ring" type as an example? I Googled and can only find the foldable and accordion style ones. Thanks!
    2018 Spyder RT Limited
    Apr 2017
    Quote Originally Posted by FalconAF View Post
    When he suggested that, I thought it was a good idea.
    But after thinking about it a bit........
    That will tend to "balloon" the cover out at the top, so if any space is left open around the bottom edges of the cover, it might tend to work like a parachute in a strong wind and try to rip the cover off the bike.
    Not so sure that is a good idea after all.
    Dec 2015
    Oakley, Utah & Yuma, Arizona
    Quote Originally Posted by solman View Post
    Hello,
    Full cover or half cover?
    The only one I know that eliminates this problem is the BRP OEM storage cover, but it's a bit heavy and cumbersome for traveling.
    2014 RTL Platinum & 2014 RTL Cognac
    Northern Utah in summer; Yuma, AZ in winter.
    Dec 2015
    just need to put something on the seat that will lift the cover high enough to prevent puddling. Could even be a bungie strung between the windshield and trunk or something like that.
    May 2017
    Mesa, Arid-Zone-A
    I have a Tourmaster 1/2 cover that I use when traveling. It fits pretty tightly with very minor pooling when I run the windscreen all the way up before installing the cover. Motel hand towels are just the ticket for eliminating cover moisture prior to morning departures. If you need to add additional strap points, most hardware stores (Lowes, Home Depot) sell tarp clamp fittings that will attach to your cover without the need to sew in additional attaching grommets. They are effective..... Jim
    Platinum Silver Satin 2014 RTL, Driver Backrest. Baha Ron Bar, Elka Shocks, Hiway pegs, Lighted Bump Skid, Centramatic Wheel Balancers, Wide Vu Mirrors, Third Tail/Brake light, Missing Belt Guard, Federal Formoza front and General Altimax rear tires, Squared Away, Mirror turn signals, Vibration Damper, Magnetic Mirrors, Matching RT622 Trailer.....Semper Fi....
    May 2018
    Jacksonville, Florida
    I have a Duraguard half cover and since I installed the Rivco flag mounts and flags it no longer fits the way it is supposed to. Which is ok as I want the Flags. I any thinking about buying a few large beach balls and blowing one up and leave under the cover to alleviate the pooling issue. The reason for multiple beach balls for me is I live in Florida and not sure how long they will last in the heat not blown up in the side covers.
    Thank you,
    Ray B.
    These are the states I have driven my Spyder Rt Limited too.
    Rimsavers -- RimBladesUSA.com
    Showchrome Tiregard (TPMS) -- motorcycleid.com
    Front and side grilles -- CanAmSpyderAccessories
    Passenger arm rest -- Diamond R Accessories
    Rear axle caps -- Lamonster
    Magic Mirrors -- Lamonster
    Yellow and red running and blinker lights on fender --Show Chrome
    TRUNK-MOUNTED, DOUBLE FLAG HOLDER -- Rivco
    Bumpskid w/led lights -- Spyderpops
    Seat cushion -- Airhawk
    Cup holders -- Drink2Go
    Ultragard-4-457BK-Black-Cover-Spyder -- Big Bike Parts
