New rear tire
Installed a altimax rt 43 rear tire ,piece of cake (son has a good tire machine ). Adjusting the belt though is a pain in the rear,what bone head engineer designed the adjusters ?
Best to leave those alone.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
First, when changing a tire correctly, the adjusters do not normally need changing. Leave the belt alignment alone.
Second, once you know how they work and how to adjust them, they work very well and easily.
One in Canada apparently, but if you do as suggested above after some research before you attack it you don't have those sort of problems.
Which size did you use? I'm looking at the 215/60 15 of the same tire.
for those wanting to see a tire change without changing the belt alignment or tension watch this.
www.youtube.com/watch?v=MWtbQPdKd8w
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
I just slacked left side 3/4 turn ,pulled axle ,removed belt . Put it back together with no problems ,belt out of align .There are easier was to make adjusters i am sure . Over & out .
JC are you still using the "lower" belt tension?
If so can you tell me what value you have it set for? I have a 2018 F3L.
Thanks, Rick
Originally Posted by pegasus1300
I like the video ,will give it a try next tire change.
Yes that is the size i installed.
BTW i could not believe how thin the old worn kenda is ,feels as thick as a balloon in the center.
I just bought that size, my second one, from Amazon, $91.34 delivered free today. Bought my first from Walmart in Feb '18 for $77.57, delivered free, but this year they wanted $107.98 with free delivery and Wally has outsourced it to a third party, Tire Bros.
So, did you get the tracking taken care of? I know exactly what you went through. For some unknown reason there are times you can reinstall the axle exactly where it was before the tire change and the belt will track differently.
Here's a long thread I started discussing problems getting the belt aligned. https://www.spyderlovers.com/forums/...m-amp-Question
I put the spyder up on my car hoist ,no fear of it falling .I did finally got the alignment were i wanted. It would be much easier to have a push pull system ,but that would make sense . I had the dealer adjust the belt three times because of burning smell , so i am not the only one that struggles with the adjustment.
Thanks, Rick
We aim for 90 to 100 lbs with the wheel lowered on the shock stop. (spec was 95). On most RTs this nearly eliminates belt vibration. Most F3s still need a tensioner to get rid of it.
I had the OEM tire it was changed @ 5,824 miles. I am now running the General Altimax RT 43 tire ( 2nd one installed this past winter.
The OEM was not safe enough to drive( bald in the center of the tire.)
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
My OEM Kenda was bald in the middle at 10,000 miles. Just had the General Altimax RT-43 installed today.
2022 Spyder RT Limited Sea to Sky Mystery Blue
