Results 1 to 18 of 18
Thread: New rear tire
    Mar 2018
    Ontario ,way up north
    Default New rear tire
    Installed a altimax rt 43 rear tire ,piece of cake (son has a good tire machine ). Adjusting the belt though is a pain in the rear,what bone head engineer designed the adjusters ?
    2018 RTL , dark blue
    Nov 2012
    North Las Vegas, NV
    Best to leave those alone.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Houston
    First, when changing a tire correctly, the adjusters do not normally need changing. Leave the belt alignment alone.
    Second, once you know how they work and how to adjust them, they work very well and easily.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    ...What most folks here do is to remove the Shock BOLT first ….. this allows enough slack to move the belt to the side and drop the wheel /tire down …. If done this way the belt alignment remains the SAME as prior to wheel removal ….. Sooooooooooooooo next time remember doing it this way ….. Mike
    Dec 2009
    West Oz
    Quote Originally Posted by stmike 1800 View Post
    One in Canada apparently, but if you do as suggested above after some research before you attack it you don't have those sort of problems.
    Nov 2016
    Edinburg,VA
    Which size did you use? I'm looking at the 215/60 15 of the same tire.
    Feb 2012
    Spring City,Utah
    for those wanting to see a tire change without changing the belt alignment or tension watch this.
    www.youtube.com/watch?v=MWtbQPdKd8w
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Mar 2018
    I just slacked left side 3/4 turn ,pulled axle ,removed belt . Put it back together with no problems ,belt out of align .There are easier was to make adjusters i am sure . Over & out .
    Apr 2013
    Hartsville, S.C.
    JC are you still using the "lower" belt tension?
    If so can you tell me what value you have it set for? I have a 2018 F3L.
    Thanks, Rick
    Mar 2018
    I like the video ,will give it a try next tire change.
    Mar 2018
    Quote Originally Posted by Genradman View Post
    Yes that is the size i installed.
    Mar 2018
    BTW i could not believe how thin the old worn kenda is ,feels as thick as a balloon in the center.
    I just bought that size, my second one, from Amazon, $91.34 delivered free today. Bought my first from Walmart in Feb '18 for $77.57, delivered free, but this year they wanted $107.98 with free delivery and Wally has outsourced it to a third party, Tire Bros.
    So, did you get the tracking taken care of? I know exactly what you went through. For some unknown reason there are times you can reinstall the axle exactly where it was before the tire change and the belt will track differently.
    Here's a long thread I started discussing problems getting the belt aligned. https://www.spyderlovers.com/forums/...m-amp-Question
    Mar 2018
    I put the spyder up on my car hoist ,no fear of it falling .I did finally got the alignment were i wanted. It would be much easier to have a push pull system ,but that would make sense . I had the dealer adjust the belt three times because of burning smell , so i am not the only one that struggles with the adjustment.
    Houston
    Quote Originally Posted by stebrock View Post
    Thanks, Rick
    We aim for 90 to 100 lbs with the wheel lowered on the shock stop. (spec was 95). On most RTs this nearly eliminates belt vibration. Most F3s still need a tensioner to get rid of it.
    Vermont
    I had the OEM tire it was changed @ 5,824 miles. I am now running the General Altimax RT 43 tire ( 2nd one installed this past winter.
    The OEM was not safe enough to drive( bald in the center of the tire.)
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Active Member george123's Avatar
    May 2017
    San Antonio, Rogers Ranch
    My OEM Kenda was bald in the middle at 10,000 miles. Just had the General Altimax RT-43 installed today.
    2022 Spyder RT Limited Sea to Sky Mystery Blue
