Results 1 to 12 of 12
    Active Member Airborne's Avatar
    May 2019
    Tasmania, Ausralia
    Default Squeaks and rattles
    Hi All.
    I love my 18 F3 LTD with 3000 km. However she squeaks at the front [suspension i figure] and the motor rattles a fair bit [hot or cold]
    I'm not particularly bothered about it but 'is it normal!' or should i be seeing the dealer about it.
    Thanks AB
    You might want to listen to the engine on somebody else's F3 & maybe even a couple of 1330 engined RT's too, just for comparisons sake of course, but I think you'll find ALL the 1330 motored Spyders sound 'a little rattly' if you're used to just about anything else!! So without any further info/detail about the what/where & how of it, THAT particular noise is most likely a 'normal for the engine' type noise, and a comparison should let you know pdq
    The squeaky front end tho, that's something not so frequently encountered so you'd like to hope it's not a sign of anything drastic. You might be able to really narrow down the focus & identify the source of that particular squeak by squirting a little water or maybe even some Windex on each moving joint in turn and then checking for the squeak while that particular joint is the only joint that's wet before moving on to the next, gradually working your way around each potential joint/bush/whatever & testing them while wet one at a time.... so tthat by a process of slow elimination, you'll eventually identify the exact source of the noise!! Yeah, it can be time consuming doing it that way but eventually you'll find EXACTLY where the noise you are concerned about is actually coming from & you can then make a 'more informed' decision on how to remedy it permanently!!
    Good Luck, and Happy Hunting!
    May 2012
    North Las Vegas
    For the mirrors get some wedges from Squared Away! They will fix the noise and vibration that should not be there!
    USAF MSgt, Retired
    2018 F3 Intense Red
    Squared Away Lasar alignment, TricLED Headlights, Foglights,Safety Bundle with Turn Module, BajaRon Sway Bar,Squared Away Mirror Wedges, Stebel Air Horn, Dash Turn Indicators, TricLED USA Flag
    2018 F3L , Intense Red
    Nov 2018
    Lisbon, Portugal
    They do squeak a bit... I know mine does.
    Got some squeaks on the front suspension and on the brakes, specially when in hot weather.
    The engine has a different sound when cold (specially on the left side). But I guess like any dry sump engine.
    2018 F3S , Monolith Black Satin
    May 2019
    Tasmania, Ausralia
    Thanks all, i will have a look at the suspension and i suspect the engine rattle is normal. With the wedges, i am not aware of any noise from the mirrors.
    I don't have an F3 but mine came with a Bajaron sway bar and it squeaked just a bit until a got a few hundred miles on it and has been quiet ever since. Now the engine, that sounds a mite like an industrial sewing machine until it warms up but who cares.
    May 2019
    Tasmania, Ausralia
    Ha! yep shouldn't worry me and doesn't, just checking!
    Maybe the suspension is just loosening up she's still fairly new, as for the motor i came off a F6B With that beautiful 1800 smoothness so i guess i'm gonna notice the difference.
    Jul 2010
    Las Vegas, NV
    Grab the mirror and see if it moves up and down. If it does, it needs a wedgie. Joe
    Joe Meyer
    Dec 2018
    ON
    The exhaust flashing coming out of the engine can rattle. I used some header wrap to wedge between it and the exhaust pipe to cure that.
    Nov 2017
    San Francisco Bay area
    My cup holder squeaks when the road is bumpy
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    May 2019
    Tasmania, Ausralia
    Quote Originally Posted by cptjam View Post
    Thanks for that, do you mean just the mirrors or the full housing.
    I see you've 'had the slipstream between your legs' AB
    May 2019
    Tasmania, Ausralia
    Quote Originally Posted by rwill2cruz View Post
    Thanks, i'll check!
