Results 1 to 25 of 27
Thread: Vibration GONE
    Mar 2019
    Las Vegas
    Default Vibration GONE
    I just wanted to give a shout out to Roadster Renovations.
    I had the dreaded 70MPH vibration in my 2018 RTL.
    After doing a lot of research on these forums it came to my attention that it was a drive belt issue.
    More research revealed that the cure to that vibration was a vibration dampener.
    A few different brands are mentioned but I decided to go with the Roadster Renovations dampener.
    Their dampener completely took all the vibration out of the Spyder.
    I can now ride comfortably at 70+ mph.
    Thanks, Roadster Renovations!
    2018 RT Limited White/Chrome.
    BlueSeaSky front & rear dash cam.
    USB plugs
    TechMount cellphone holder
    Squared Away laser alignment.
    BajaRon anti-sway bar and links.
    Dynojet
    Ceramic coated cat delete pipe
    Jul 2010
    Las Vegas, NV
    Hi!
    We will have to get together when we get back from Washington. Joe
    Joe Meyer
    May 2019
    NC
    my 18rt has the same issue at 71 to 73 is this work considered warrenty issue if it is so common?
    Mar 2019
    Las Vegas
    Quote Originally Posted by fastfreddy View Post
    Not from what I have read on here.
    Mine is due for the first service soon. I will ask them
    USB plugs
    Dynojet
    Mar 2019
    Las Vegas
    Yes, joe!
    USB plugs
    Dynojet
    Jun 2015
    Hampton Roads, VA
    Nope. BRP even sells one as an add-on, so they know about the issue. Of course their product is junk, bearing blew out. BRP upped the tension a while back trying to get rid of it. The only good, permanent solution is a belt dampener. Good news it is easy as heck to put on. Had mine installed two weeks after I bought my 2016 RTS. 35K miles no issues with it.
    Apr 2017
    North Central Florida
    NO.
    But if you have the problem, try a small adjustment to the belt tension first.
    BRP spec's have come down in recent years.
    Mar 2015
    Tacoma WA.
    Also check the overall belt tension with a Krickit 2. I run my belt at 170 lbs. along with a tensioner. I have no vibration, and the whine that appeared between 40-50 mph which is common among the F3 units is gone too.
    2017 F3-S Daytona , Yellow and black
    Member Bill's Avatar
    Saratoga Springs,NY
    Default Doc’s vibration damper installed in less than an hr.
    got it out of the mail box opened it and looked it over read the instructions and an hr. after that I was test riding around the block and a quick recheck and I was putting the Tupperware back on.
    As for the ride no more of that fine vibration that puts your feet to sleep. Gone! Now when you back off the throttle around 70 no more vibration, smooth as a baby’s behind....
    Thanks Doc . Love the alignment jig !C8BD8803-F56A-40D9-A920-A61337B656D1.jpg08DAA45B-727F-4E85-B5F4-6F0BE19563FC.jpg
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Same issue with my 18RT. Belt dampener is not a warranty item, however I raised enough hell with my dealer and BRP that they installed one at no charge.
    BRP is well aware of the situation and should warranty that. Again, insist with your dealer. Should be FREE....
    Now some on this board would rather buy an after market. The one installed on my bike is from BRP and falls under the bike warranty. A year and a half and 8000 smooth miles...
    2018 RT Limited "Blondie"
    Northern Kalifornia
    Quote Originally Posted by VegasSpyder View Post
    Do you know what your belt tension is checking it with the Krikut gage and with your tire on the ground?
    Apr 2016
    Bloomington, Minnesota
    I think that BRP has it as an accessory, otherwise they would be facing a lot of money sunk into warranty claims. This way they aren't liable.
    I have to say that I was really disappointed when I drove my 2019 away from the dealership. I had the dreaded vibration from 62 to 77. It seemed to lessen after after 300 miles, but still was pronounced enough to get me motivated to buy the damper.
    Jun 2019
    Canuckistan
    Quote Originally Posted by PapaHotel View Post
    Howdy;
    Now this is causing me some concern. The Only accessory I see in BRP (Canada's) site is an 'Idler pulley Service kit': https://www.brp.ca/on-road/shop/spyd...er-pulley.html.
    Of course - no pics and it's too inexpensive to be the full accessory (?). Anyone have a part number fer the alleged OEM full tensioner handy? I see reference to: 219800431, buy I fear, after perusing parts site, the 'idler' isn't related to the 'tensioner'. Gahhhh.
    I will ask about this on Saturday.
    Lastly - I will be sure to ask if the new 'lower' belt tension spec was applied @ PDI, and what that spec is - problem is I'm not certain they will translate that into a 'Krikit II standard' value I can relate to, lol. BTW - I bought one o' them puppies - wonder if I should bring it to pish off the tech. Nah... that sounds counter-productive,lol.
    I really, really don't want to get halfway home, only to discover I'm ryding a vibrator, and having to turn around for them to tell me it's 'normal'. That dawg won't hunt, aight.
    Perhaps I should bring the KII and the spec I want to see (~170 lbs ), so they realize they's not dealin' wif some clueless coprolite Millennial wif a man-bun (a.k.a. Millennial Mullet).
    2019 F3L. Yep - I realize this is the RT fer'm - but this afflicts the other models as well. My bad.
    Thanks and Cheers
    E
    USA
    As I've read some tales of people taking a well tuned and not vibrating machine into the dealership, and coming away with their belt tension too high and now vibrating. My suggestion is if you own a Spyder, learn how to at least adjust the belt tension and align the belt. It's really not that hard, and barring physical infirmity almost anyone can accomplish this task. The hardest part is getting the correct torque on the axle nut. Apparently some dealers are stuck on stupid about the "correct" belt tension.
    h0gr1der
    Northern Kalifornia
    Some are also stuck on stupid regarding axle nut torque.
    Apr 2017
    Quote Originally Posted by Entropy View Post
    I think you are making WAY too much of this.
    Not all owners even have or notice any vibration.
    Those that DO typically only have it in a fairly narrow range of speeds.....like 70 to 80 MPH.
    So....until you get this sorted out......if you do have a vibration, either slow down or speed up a bit and it likely will go away.
    Or just ignore it. It is NOT damaging anything.
    Jun 2019
    Canuckistan
    Howdy;
    I do hear ye, sir. Thankee fer that.
    I'm blessed/cursed with an over-abundance of curiosity, and am predisposed to having thangs that Don't happen to most folks, happen to ME. lol. Hence I always plan ahead, to at least attempt to get out in front of it. Sometimes this even works, lol.
    To be clear - the repeated advice on this site to just go ryde yer shiney new conveyance and not incur WFFL or be overly-concerned with things that *might* happen - but usually don't - is most appreciated.
    So far I've limited myself to the axle nut socket, a KII, some mesh riding gear, a UFIT component, oil and o-rings. So far, lol.
    Regards & Cheers
    E
    Jun 2010
    Las Vegas
    I had the ‘Million Mile’ dampener from Roadster Renovations on my F3T and it failed at less than 50,000 miles, wrecked my belt. I sent Doc a photo and his reply was a thumbs up emoji. Not a happy customer here.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    You ran this eight years for 50,000 miles? How long has anyone else had Docs ‘Million Mile’ dampener last?
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
    Jun 2010
    Las Vegas
    Quote Originally Posted by MeudtPG View Post
    No, I ran it 1 1/2 years for 50,000 miles.
    2010 RT- 622
    Aug 2018
    Monroe, WI
    Didn't Docs tensioner warranty say "Entire kit will be warranted against defects and roller and bearings will be 2 years, regardless of mileage"?
    Maybe he didn't know you had 1-1/2 year with this failure.
    Northern Kalifornia
    Was it just the roller that failed, or did the bearings fail causing the roller to fail also?
    USA
    Ms SpyderAnn01,
    Did Doc get back with you on this? I just put one of these on my bike, and I'd like to know how this goes.
    h0gr1der
    Jun 2010
    Las Vegas
    I don’t recall what his warranty said but I do know he refers to it as a ‘million mile’ tensioner
    QUOTE=2dogs;1452466]Was it just the roller that failed, or did the bearings fail causing the roller to fail also?[/QUOTE]. The bearing failed
    Quote Originally Posted by h0gr1der View Post
    Ms SpyderAnn01,
    As I said when I sent him a picture and told him what happened his reply was a thumbs up emoji. I then asked if he had repair parts or if the unit was junk and he never responded. Joe sent him an email and he has not responded to that either.
    2010 RT- 622
    May 2019
    NC
    just got the 3k service and 3 wheel align, bike handles much much better, but now have the 70 mph vibration, sunday I am adj belt and dropping on my new doc belt dampner, will report back after
