Results 1 to 16 of 16
    Active Member Sarge's Avatar
    Apr 2019
    Yanceyville,NC
    Default Instrument panel turn indicator
    OK. I've not had even 50 posts yet, but, I've done a fair share of reading. I've also got a couple daze of wrenching on various vehicles. I know the instrument turn indicators are worthless in daytime hours. I have replaced the micro led instrument bulbs on a truck I once owned. They too were worthless even at night. I got the bulbs from https://www.superbrightleds.com/. They worked great and were dim-able. SOOooo ... here's the question. Has anyone looked into replacing the instrument turn indicator bulbs? I'm guessing they are LED. I haven't found a drawing of the instrument panel or the bulbs yet and will try to pull the panel off the trike sometime in the next couple of weeks. Any info would certainly be appreciated.
    Ride Safe.
    Shoot Straight.
    Speak the Truth.
    David & Deb Parsons
    "Sarge"
    2015 Circuit Yellow Spyder RT Limited
    2010 Velocity Yellow Kawasaki VN1700 Voyager
    AMSOIL
    AMA Member
    AVA Member
    VROC Member
    KawaNOW Member
    Patriot Guard Rider
    US Army M.I., Retired
    NRA Instructor & N.C. CCW Instructor
    Never mind Area51. Worry about the other 50, or more!
    2015 RT Limited , Circuit Yellow
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    It's my understanding that the cluster is a sealed unit. I do know the indicators there are indeed worthless,
    as is most of the other info displayed there for my old tired eyes. Many have installed the l.e.d. mirror lights that activate with the turn signals
    giving a most obvious sign of the blinkers running. I am grateful that the self cancelling function on the RT is much better than most.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    I don't know, but I put turn signal LED strips on each of my mirrors and I'm so pleased. Search for ****-*** (without the dash) and you'll find them under their RT products.
    Rob
    Last edited by Peter Aawen; 06-12-2019 at 01:17 AM. Reason: Avoiding word substitution
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    May 2017
    Mesa, Arid-Zone-A
    Turn signals mounted to the outer edge of the mirrors are what I did. Mounted correctly, they are not blinding to the driver but can be seen. More importantly, all the others on the road, front, side and rear, can see them very clearly. Easy plug and play and not expensive. One of our vendor sponsors, Spyderpops sells them. Check it out..... Jim
    Semper Fi
    Jul 2010
    Las Vegas, NV
    We do a LED industrial light on the dash. Go to any Industrial supply house, get a pair of green LED lights, wire them to the turn signals, and you are good to go. Call me for specifics. Joe
    Joe Meyer
    Bossier LoUiSiAna
    Quote Originally Posted by cptjam View Post
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Nov 2012
    North Las Vegas, NV
    I got a pair of LEDS at the auto parts store and mounted them in the speaker grilles and wired them to the mirror power.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    Here ya go. Bought off Amazon, think about 6 or 7 each. Perfectly visible during the day, dont mess with the cluster, just wire into the wiring that goes to the mirrors.
    2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
    2010 RT SE5 , Black
    Mar 2019
    Las Vegas
    I will have to stop by and see what you have done. I too have a problem with the stock turn signal indicators.
    2018 RT Limited White/Chrome.
    BlueSeaSky front & rear dash cam.
    USB plugs
    TechMount cellphone holder
    Squared Away laser alignment.
    BajaRon anti-sway bar and links.
    Dynojet
    Ceramic coated cat delete pipe
    Default Well yes.....
    We had a fellow back in 2012 from south america that wanted to change the color of the dash lights. Bob Denman and I help all we could and he did venture into taking the cluster apart and replacing the bulbs but not something anyone would recommend. You are much better off with the suggestions from those above...
    20181202_110707.jpg did add the led to the upper corners of the dash and works great....
    ​2012 RS sm5
    Apr 2019
    Florida Swamp
    I wired some of the little LED tag light bolts into the turn signals on my old Sportster. They plenty bright enough to see and use very little power. They been on there for 7 or 8 years now and still work fine. I think I got them from Summit Racing, but the auto parts stores should have them too. Got red one for low oil pressure, 2 green ones for turn signals, and a white one for the neutral light.
    2019 F3-S , Black & Silver
    Apr 2016
    St. Charles IL
    Quote Originally Posted by Sarge View Post
    I solved that problem by mounting two (one on each side) 5mm flat top LED's (along with the proper resistor) wired into the turn signals. Easy peazy! Send me a pm with your email and I'll send you a pic of what it looks like.
    Bill W
    2019 F3 LTD
    Apr 2019
    Yanceyville,NC
    Thanks everyone! Don't know why I didn't think of the LED bolts in the dash. That's an awesome idea. That's what I'm gonna do.
    Ride Safe.
    Shoot Straight.
    Speak the Truth.
    David & Deb Parsons
    "Sarge"
    AMSOIL
    AMA Member
    AVA Member
    VROC Member
    KawaNOW Member
    Patriot Guard Rider
    Apr 2017
    North Central Florida
    No. But I did add turn signal strips to my mirrors.
    Fairly easy process with the supplied hardware and instructions......once you figure out the right way to get the mirrors off.
    They are visible not only to you but the the driver in the lane next to you too.
    MUCH easier than what you propose.
    Active Member BearX16's Avatar
    Jun 2019
    East Central IL
    I just had RT Longhorn RT LED lights installed on my mirrors on a 14 RT S. Light is visible to rider but are not blinding and very visible front side and rear. Purchased from LAMonster Garage along with the mirror magnets. Lights are plug and play.
    Nov 2018
    Claremore, Ok.
    That's what I did also. except that I ordered these from Amazon. 2 of Alpinetech PL12MS 12mm 1/2" 12V LED Metal Signal Indicator Pilot Dash Light (Single Arrow (Green))
    Sold by: ATI Store
    $8.95
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
