Results 1 to 17 of 17
Thread: Brake failure
    Feb 2019
    England
    Thumbs up Brake failure
    Hi al just a bit of info ref readout on dash After riding a few miles , had a reading of BRAKE FAiLURE on dash . I stopped and turned engine off , put parking brake on , then started again , took p/brake off road away NO more readout Conclusion make sure P brake is fully Down
    Regards Nico 75
    Make sure your brake fluid reservoir is full.
    Apr 2017
    North Central Florida
    +1 on checking the fluid.
    The parking brake is electrically operated......so there is no way to "make sure it is fully down".
    Also be sure you aren't "riding the brake" by accident.
    Active Member poli's Avatar
    Feb 2019
    East Texas
    The 'parking brake' is cable operated, but it is my understanding it has nothing to do with the brakes, it just locks the transmission up.
    Spyder F3-S Special Series my traveling ride
    Ryker Rally modified for dual sport duty
    Honda Grom heavily modified for dual sport duty
    Ducati Scrambler Icon Dark my other traveling ride
    Sep 2016
    Chillicothe, Oh.
    Does the Ryker have the same parking brake set up as the Spyder where the cable applies the rear brake? Inquiring minds want to know
    2015 RT , Black
    Feb 2019
    East Texas
    No. After you stop and apply the 'parking brake', you can get off and by hand roll the bike back and forth a few inches and then you can hear and feel it locking the transmission up.
    Default Much like.....
    Much like the fuel level can vary with the angle of the ryde.... you know up hill down hill.... the brake fluid can do the same if a bit low. Agree with BajaRon on checking the level nonetheless....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Feb 2019
    England
    Hi easyRider there seems to be conflicting views n operation of p/ brake ie cable or electronic ? Any way make sure it's fully down regards Nico 75
    Apr 2017
    Quote Originally Posted by Nico75 View Post
    What do you mean by "fully down" ?
    It is a combination of an electric solenoid (motor) and a cable.
    Active Member bcraig's Avatar
    Grove City, OH USA
    There is a new service bulletin pertaining the the Master Cylinder Diaphragm needs replaced. My dealership told me about it yesterday and ordered the parts. I haven't had any problems myself, but the dealership is being proactive.
    No, it's not on the Ryker; and this is in the Ryker section.
    The Ryker's 'park brake' is operated by a lever - UP is ON, & when it's flipped fully DOWN, the park brake is OFF.
    When the top of the lever is pulled out from its UP & ENGAGED position & rotated thru a 180° arc into its fully DOWN position, the park brake is set OFF. Failure to complete the entire 180° swing of the lever's swing can leave the lever only partially down & the park brake not yet fully disengaged, but if it's moved juuuust far enough, it'll let you ryde... for a while anyway! Hence, Nico's post & warning.
    Bossier LoUiSiAna
    Quote Originally Posted by bcraig View Post
    Ryker or Spyder
    Grove City, OH USA
    Ryker or Spyder
    This is the Ryker forum - So it's pertaining to the Ryker
    Apr 2017
    Oops. Sorry.
    In my defense, the "subscribed threads" scan does not show which section the posts are IN.
    (Yea, weak excuse......but it's all I've got.)
    Oops. Sorry.
    Catches me pretty much every time....
    But before I submit a post, I double check where I am in the heirarchy of Forum sub-sections by looking at the Forum address line up the top left of the page. It's just above the vendor adverts but below the black menu line & the grey 'drop down lists' line; the line with the tiny little house/home button to the left/alongside it that usually starts with 'Forum' or 'Search' etc then has a little arrow or two, maybe three leading you thru the various subordinate forum sections/actions that brings you right down to whichever section/sub-forum you're actually in. Doing that 'double check' just before I hit 'submit' has (narrowly!) saved me from posting Spyder info into a Ryker thread more'n once!
    So check that Forum line; to be sure, to be sure!
    Bossier LoUiSiAna
    But then the post count goes down
    Bossier LoUiSiAna
    Regards Nico 75
    Ok additional info please for us without a Ryker, does it fuss (alarm beep)at you when you remove the dongle with Pbrake not on, or when you apply throttle when in gear & Pbrake is on? My Spyder does anyway, but also has a key not a dongle thx
