Results 1 to 17 of 17
    Aug 2018
    north wis
    Default Are there any Back rests that fold forward or slip in/out readily?
    Read a lot of reviews on backrests and I see that some fold forward to ease access to passenger seat. My question is- do any of them slide out of the slot and go back in with no tools ? I ask because my wife likes to get on the RT on the drivers seat and then scooch back. Thanx!
    Active Member Nokesy's Avatar
    Mar 2017
    Newmarket
    I have an ultimate seat with back rest and you do not need tools to pull backrest out. you can also adjust the backrest with your fingers. The drivers rest folds forward as well.
    Done all of Canada except NWT and parts of Australia, New Zealand and areas of Europe
    Very Active Member h0gr1der's Avatar
    Apr 2019
    USA
    The OEM adjustable backrest on my 2018 RTL is locked into the seat to prevent theft, but a flip of the under-seat clip frees it for removal. It folds forward to aid in mounting the bike, and uses an Hex wrench to adjust the angle for comfort.
    h0gr1der
    2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
    States Visited on Less than 4 wheels.
    Bryant, Arkansas
    Cruzr joe
    Active Member starrider60's Avatar
    Aug 2017
    laurel, mississippi
    What h0gr1der said. I have the OEM backrest and love it
    Aug 2018
    north wis
    Just so I'm clear,the oem rest,once released,would go back in and stay there without the clip? Be hard to raise the seat with her on it!
    Aug 2018
    north wis
    I also have an 18 rtl
    Apr 2019
    USA
    Quote Originally Posted by woods View Post
    Not sure what you're asking here, but the seat backrest works this way. Installed, it folds forward to ease passenger mount or dismount. Also, you can remove and easily reinstall the backrest by opening the seat, pushing the retention clip to the side, and pulling the backrest up and out of the socket (first time is hard, you have to pull in an Upward/forward direction). Some folks remove the backrest and throw it in the frunk when riding double. It locks in place every time when installed. Does that clear it up?
    h0gr1der
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Quote Originally Posted by h0gr1der View Post
    "to prevent theft of a backrest"?? That's a new one for me. I didn't know that backrest get stolen. I have the Ultimate seat with backrest. It push and pull out really easy. It folds forward and can adjust the angle by hand. No tools needed. And the best part is that you can fill the tank without asking the wife to dismount (which by itself is a win/win situation)
    2018 RT Limited "Blondie"
    Apr 2019
    USA
    Quote Originally Posted by Bigmo View Post
    You be surprised what folks will walk off with. If your truck has a backup camera in the tailgate you better lock it when leaving it alone. The world isn't what it used to be. I had Misty Mountain make my driver backrest sheepskin so the straps are locked under the driver backrest, you guessed it, to keep idle hands from doing the devils work.
    h0gr1der
    Aug 2018
    north wis
    The wife is a bit,um,vertically challenged at 4'10" and gets on the drivers seat first then scoots back. Removing the backrest and stowing it when 2 up sounds like the answer! Thanks!
    Aug 2018
    Vancouver, WA
    If your wife is unable to climb over the backrest to get off the bike, then Woods suggestion is the best advice; at least when using the OEM seat and backrest.
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    My 2014 RTS came with the Can Am back rest. I took it off to ride 2 up, now can't seem to get it back in. So I tossed it into the garage. Kind of annoying really.
    2014 RT-S , Orange
    Apr 2019
    USA
    I found the key to the OEM backrest was to angle the 2 mounting prongs toward the back while inserting the backrest into the seat. First couple of times it was hard, then eased up. Mine limbered up and now is pretty easy to use, getting it on and off. Hard part is reaching under and finding the latch while trying to pull the backrest.
    h0gr1der
    Jul 2019
    Georgia
    Thanks for the info. I'm 5'3" and just added the OEM backrest. I really needed to adjust it forward. Thanks again.
    Quote Originally Posted by Spydermom View Post
    Another old thread from the archives. This one goes back to 6/2019.
