Results 1 to 16 of 16
    Nov 2018
    Des Moines IA
    Default Sadddlebag Issues
    My wife has a 2018 RTL. A couple of weeks ago the left saddlebag wouldn't open so she took it to the dealer. They adjusted both saddlebags and now the right one continually pops open. 8 times in a 100 mile ride to be exact. When we took it to the dealer on Saturday, the tech said she wasn't slamming it hard enough. He closed the saddlebag and said that was all he could do. Needless to say my wife is usually a pretty calm girl. They are installing a new rear tire this Thursday and I think my wife may rip him a new one if they can't fix the issue. Not a real confidence inspiring feeling when you dump the contents out on the rode at 70 MPH.
    Now for the question: On a lot of side opening saddlebags (Panniers) they install a strap on the inside to keep the luggage in place. Does anyone make an aftermarket kit to do this?
    2018 Spyder ST Limited , Asphalt Gray
    Nov 2018
    Waynesboro, PA
    Might try this if you work on the bike yourself. https://www.spyderlovers.com/forums/...ble-Adjustment You can also fine many different types of cargo net stuff here http://store.valueaccessories.net/luggage-5.aspx and other places. Just click on the links I gave you.
    2012 RTL , Brown
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    sounds like they tensioned up the cable a little too much. Hoping to avoid a return visit ?
    IT really is a simple thing, and I know you'll get it sorted out.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Nov 2018
    Des Moines IA
    Quote Originally Posted by CopperSpyder View Post
    Thank you for the video. It does look like it is easy enough to do.
    Value Accessories has luggage but nothing to actually secure the luggage in the bag. I may have to come up with my own solution.
    Nov 2018
    Waynesboro, PA
    There are two different sets of cargo nets there also that bolt in using the same bolts that are already there on the side bags
    2012 RTL , Brown
    Active Member Sarge's Avatar
    Yanceyville,NC
    I read somewhere that you should always LOCK the trunk/side bags when moving. If you're doing this and they still pop open, I would see the dealer.
    Ride Safe.
    Shoot Straight.
    Speak the Truth.
    David & Deb Parsons
    "Sarge"
    2015 Circuit Yellow Spyder RT Limited
    2010 Velocity Yellow Kawasaki VN1700 Voyager
    AMSOIL
    AMA Member
    AVA Member
    VROC Member
    KawaNOW Member
    Patriot Guard Rider
    US Army M.I., Retired
    NRA Instructor & N.C. CCW Instructor
    Never mind Area51. Worry about the other 50, or more!
    2015 RT Limited , Circuit Yellow
    Aug 2013
    SF Bay Area
    I have to lean on the bag lid or lightly punch the lid when holding the rear latch and the lids pop open. Have yet to have them pop open on their own. Don't think I'll get them adjusted as I like it that they stay closed. Might try locking them while riding.
    2021 F3 Ltd , Magna Red
    Nov 2018
    Des Moines IA
    Originally that was the issue with the right bag. It wouldn't open without pushing on the lid. I took the back end apart last night and adjusted the cable. Hopefully I have it fixed.
    Locking the bag all the time is a pain in the ass and shouldn't be required.
    Quote Originally Posted by lstayner View Post
    I feel yout pain .... Look at this E-bay item #252626422909 ….. I think it will solve your problem and your anxiety …… sorry I can't do LINKS ...…….. Mike
    Nov 2018
    Des Moines IA
    Yah.........NO. LOL
    Yah.........NO. LOL
    I apologize, if that offended your tastes..... it won't happen again ….EVER ...…......Mike
    Blue Springs, Mo
    If you read the manual you should bump with your hip after closing. I lock my trunk no matter what. Have inside luggage and nets that use oem bolts work great. Nothing works better IMHO then lock.
    I don't think that will help anyway. If the latch of the saddlebag is not adjusted correctly locking the trunk won't help. All the lock does is prevents one from pulling the release handles. There is no direct connection between the lock and the latches.
    Jul 2010
    Las Vegas, NV
    Mac is right. 8 screws, slip off the back panel, adjust the cables, put back together. Call me(number below) and I’ll walk you through the entire process. Pretty easy. Joe
    Joe Meyer
    Mar 2015
    Fritch, Tx
    That video near the top is a great help. I did notice the part trying to show the adjuster was a bit on the blurry side though. I had to adjust my right bag last year and took a few pictures. Hopefully this collage shows some parts a little more clearly. I also found that getting the door damper out of the way helped get to that one screw behind the lid. (red arrow)
    Those who say " I can't" will always be right.
    Nov 2018
    Des Moines IA
    My skin is quite a bit thicker than that! LOL
