Results 1 to 16 of 16
    Active Member BryanSD's Avatar
    Jun 2018
    South Dakota
    Default Pool of Water in the Frunk
    The last couple times I've washed with soap and water my RT (mostly using sponge and no pressure hose), I've found water in the front trunk. I'm not talking moist but along the lines of a bucket of water. Is this just a problem with my 2017 RT or is this a common problem? Any solution?
    Given with what I see, I can't see any better way of closing/sealing the frunk so water doesn't seep in. Seems more like a design issue than a "me issue". But who knows. Given that I haven't driven the RT too much in the rain and store it in the garage, I can't tell if this is a problem I only see when the RT is parked and at standstill or also a problem also when riding in the rain. Either way, the wife isn't going to be happy to see her few clothes she's traveling be sopping wet if it rains. Any suggestions?
    2017 Spyder RT Limited - Champagne Metallic Chrome
    - Wolo Bad Boy Horn, SPYDERPOPS Next Gen LED Bumpskid, SPYDERPOPS Double Vision Daytime Running Lights
    2021 Spyder RT Limited - Deep Marsala Metallic Dark
    - Replaced 2021 Stock Handlebars with F3 Stock Handlebars, BRP Adjustable Driver Backrest, Wolo Bad Boy Horn, SPYDERPOPS Double Vision Daytime Running Lights, SPYDERPOPS ""BRAKER BARS" Brake/Run Lights
    Bryant, Arkansas
    check and make sure that the rubber seal is properly in place (you do have a rubber seal, right?).
    check and make sure that the Frunk lid is properly closing all the way.
    check that the rubber seal has no broken or cracked areas, if so replace it.
    Cruzr Joe
    Mar 2017
    Salisbury,NC
    if you accumulate too much water, there is a rubber plug on bottom under the fleece liner that you can pull
    Cruzr Joe
    ………… and also check that the seal around the Battery cover is in/on properly .... aaaaaaaaaaaaaaaaaaaand check the FUSE box covers …both sides ..... I also had water in frunk and discovered one of the fuse box covers wasn't tight ...... , after fixing NO more water in Frunk ..... I also drilled small holes in each corner , no water came in from doing that ..... Mike
    Jun 2018
    South Dakota
    This could be the issue. The last time I washed the RT I avoided the frunk lid as much as possible but still found water in the frunk. When I was drying things out I thought about checking the battery cover looked loose (but didn't check it firther) I wonder when I took my Spyder in it's 3000K checkup they didn't tigten some of the battery/fuse covers. I'll check it out! Thanks!
    Mar 2015
    Fritch, Tx
    My money is on this; mine had water in it a couple of different times and turns out the battery cover was improperly installed allowing water shedding from the windscreen area to flow into the frunk.
    Those who say " I can't" will always be right.
    Dec 2015
    Oakley Utah
    It's not you and it's not the design of the bike's bodywork. So it's got to be something else.
    If you bought it used, check to see if the previous owner made any modifications in or around the frunk 'lip' (where the gasket goes) that created a path for water to get in.
    2014 RTL Platinum
    Pete I know you are trying to help on this ….. But have you read ALL the other Posts ????? /…………………….. Mike
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Never had an issue with my '15 RT. Check your lid seal as it's not impossible for it to get pulled and to the side, particularly towards the top rear of the frunk.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Dec 2015
    Oakley Utah
    Which ones do you mean, Mike?
    2014 RTL Platinum
    Durham,Maine
    Careful Pete you'll end up on his bad boy list!!!
    2012 RTL , Pearl
    Jun 2018
    South Dakota
    No mods on the RT...purchased new by me. I'm going to take a look at the battery cover and fuse covers as Mike suggests. Perhaps when I hosed under the Spyder...that's how the water seeped in.
    Jul 2011
    Mitchell, Ontario, Canada
    Rarely is it going to leak around the top hood gasket. Even if the gasket is bad. Some folks drill holes for battery tender cable or other wiring. I have seen posted, the battery tender cable wedged between the battery access cover. Fusebox access covers not install fully maybe. Most likely it is the battery access cover not installed correctly. Bottom or side pins not hooked. That leaves a gap.
    Blue Springs, Mo
    I would definitly check my frunk un zip and make sure my fuse box is dry. Not the first time they were wet! Please check if it was that wet! It happens to the RTS. THe boxe's are suppossed to be water proof but on our 2014 they are not, check them.
    Jul 2011
    Quote Originally Posted by dcarver View Post
    You are confusing water leaking into the trunk from the fuse access covers and water leaking into the fuse box. Two different covers and completely different unrelated problems.
    Jun 2018
    South Dakota
    Quote Originally Posted by BryanSD View Post
    Update. Three Spyder washes, one huge storm while parked, and one huge storm driving...and a dry frunk. Looks like the culprit was a loose batter cover. Thanks to all those that made the suggestions.
