Results 1 to 13 of 13
    Feb 2016
    Default 28000 mile service
    Just completed the 28000 mile service on my 2015 RTL. It's a lot of work, and took about 10 hours total. If I had to do it again, I could probably do it all in about 6 hours. I spent a lot of time looking for shortcuts that just weren't there! Especially when it came to the spark plugs. I've never had the frunk off before, but it actually took longer to remove the bumpskid to get to the 2 lower bolts.
    2020 RT Limited , Marsala Red
    USA
    What was the gross cost of the maintenance?
    h0gr1der
    Feb 2016
    Quote Originally Posted by h0gr1der View Post
    Somewhere between $350-$400. That was for oil, HCM, fuel, & evap filters. Engine oil, coolant, spark plugs and some misc oetiker clamps.
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Good value. I had my dealer do mine and it was about $900 parts, labor, and tax. This also included AmsOil, which is a bit more expensive. I just didn't want to tackle all of it myself. I might do Jacque's F3S when it comes time or I might have my dealer do all or some.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Hmmm, $900? Guess I'll be doing it myself. What parts do I need? Seems a little excessive to be replacing iridium spark plugs at 28k. Those are usually good for 100k in cars/trucks.
    2014 RT-S , Orange
    Quote Originally Posted by Wahrsuul View Post
    These are the costs per item if you get them through me.
    SE6 Trans Filter - $96.50
    SM6/SE6 Oil Filter Kit - $13.95
    SM6/SE6 Spark Plug Set - $27.95
    Total - $138.40
    Prices include shipping. There will be tax if you live in Tennessee. You can see all of these items and more by clicking on the link below.
    https://www.spyderlovers.com/forums/...rs-amp-Helmets
    I do not carry the fuel or Evap filters.
    I also carry Amsoil for the Spyder. It usually runs about $13.50 per quart if you just get 5 quarts. About $11.50 per quart if you get a case of 12 quarts. Of course there are less expensive options for oil.
    Feb 2016
    Total - $138.40
    I did get a lot of this from Ron. He's great to deal with and has very fast shipping. The 28k service does call for coolant change also. Ron, you need to make a "coolant change kit" which would include the Oetiker clamp for the lower radiator hose. I had to source that elsewhere and pay astronomical shipping. Brett
    May 2019
    Springdale Arkansas
    Total - $138.40
    I’m wanting a quote on an oil change kit for my 2013 RT Limited. Shipping to 72764. Thanks in advance
    2013 Spyder RT Limited , Metallic Brown
    I have 45,000 + miles on my plugs …. I don't think there are any issues …. jmho …. Mike
    Houston
    I agree with Mike here. I have done spark plugs on a couple 1330s at 28 to 30 and one that had 50k. Old spark plugs were running fine and looking at them and measuring the gap, the old plugs had many more miles in them. There was no noticeable improvement for changing them. For most its not worth the effort and labor cost to change them. No idea how long they will last but usually when the gap grows, idle quality and fuel economy suffer. If you know your bike, you will know when its time...but its a long time with the iridium plugs.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Aug 2012
    Central Coast, CA
    I changed my plugs out at a little over 35k miles and mine were noticeably worn once I got them out and inspected. Once new ones were installed the did bike run better.
    2020 RTL SE6
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Coolant time saver tip. If, it works for you?
    Why I do it this way.
    Had the dealer do my first coolant drain and replace, as luck would have it when the tech pulled the radiator drain plug, it broke. That put the Spyder out of service until a new radiator arrived.
    So since then, once a month I evacuate and refill the coolant tank with around 28 ounces of fresh stuff(always kept at the full/MAX mark).
    Takes less than 10 minutes.
    Also keep NAPA's coolant test strips on hand to check coolant quality & PH, as needed.
    Because there's always fresh coolant being introduced, the coolant system stays happy and healthy year round.
    This may or may not work for you. It has worked for me.
    Quote Originally Posted by Jerbear View Post
    Yep - a - roo , that will definitely work ….. It will work twice as well if you do it every TWO weeks ….. all the best …. Mike
