Should be plenty. I just had to barely pull on the cables to support the 3" SC riser without the BRP 1". Should be easy to get an extra 1".
'08 SE5 #123 - Red - F1 Slider - BRP Comfort Seat - Spyder City 3" Riser
Alignment Specialist
You might want to wait until R/T has a fix for the steering lock...right now, if you get the riser, you will lose your steering lock function....some might not care, some might.
I park a lot on hills (for some odd reason), so a steering lock is important for me...
I only have the BRP 1" right now...
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
i do know with a 1 inch brp and NMN 3" they reach cut a couple zip tie's ,no problem.not familiar with the riser's your using
HAPPY TRAILS SPYDEE PE#53
