Results 1 to 11 of 11
Thread: Vibration
    May 2012
    Southern California
    Default Vibration
    I am curious...are the belt tension/vibration devices used to eliminate 1st gear take vibration? This vibration is the only vibration I experience and it is gone by 10-12 Mph.
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    Nope.
    How old would you be if you didn't know how old you were?
    Apr 2017
    North Central Florida
    No.
    That is a bit unusual though and you might want to have a shop take a quick test ride.
    Could be a chattering clutch.......or something loose.
    My ride: '17 Spyder RT
    Sep 2014
    Scotland UK
    Nah, if you're referring to the Spyder RT 1330, the low revs vibration is an engine characteristic. It needs to be dealt with by BRP, where there's a will there's a way...but there doesn't appear to be a will... Notably, it doesn't exist on the 998 Spyder.
    Apr 2017
    Quote Originally Posted by Spyderlass View Post
    Not with my 1330 it isn't.
    Sep 2014
    Scotland UK
    Quote Originally Posted by Easy Rider View Post
    Ah, yours is obviously special....
    Apr 2017
    No it isn't.
    May 2012
    Southern California
    After reading more on this issue it does appear to be a characteristic of the 1330 engine. It appears at ow RPM's ad dissipates quickly after leaving from a stop.
    Apr 2019
    Blue Springs, Mo
    We have been blasting down the road with KC SPYDER RYDERS since 014. Share every thing. F3 RTS or other it is at speed of 69 to 70 Vibration. Never is it at lower speed or gear. If you have that problem what does it do at higher RPM?
    Apr 2019
    Blue Springs, Mo
    Do not read it live it.
    Mar 2019
    Las Vegas
    I have a 2018 RTL. The only vibration that I have... or, HAD was at about 70MPH.
    I just installed the Roadster Renovations vibration dampener and that completely took care of that vibration.
    [SIGP[/SIGPIC]2018 RT Limited White/Chrome.
    BlueSeaSky front & rear dash cam.
    USB plugs
    TechMount cellphone holder
