Results 1 to 5 of 5
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Default Anyone do SE5 Clutch replacement I have 2013 RT-S
    I would like to how difficult it was to replace to install a new clutch kit for SE5. Also how many miles on the bike before needing to replace the clutch. Thanks
    Ride safe!
    2022 Sea-T0-Sky
    May 2018
    NJ
    Old thread but ANYONE?
    First, I would ask why you feel the need to replace the clutch? Treated right, the clutch on a Spyder should last a very long time. More miles than most will ever put on their Spyder. Using the wrong oil, or running your SE5 at too low an RPM can send your clutch to an early grave. But other than these things, your clutch should be pretty much bullet proof.
    Dec 2009
    West Oz
    The SE5 has 2 clutches - the centrifugal one referred to above and the normal (SM5) clutch. I've had the clutch pack out of my SM5 to replace an oil seal on the water pump shaft. Which one are you specifically asking about?
    May 2018
    NJ
    The SE5 clutch. Not the SM5, Thanks
