Page 1 of 4 1234 LastLast
Results 1 to 25 of 79
    Apr 2019
    Jacksonville
    Default Loud whining sound at idle after a fairly short run
    I have a Ryker 600 Ace with about 600 miles on it. It runs great!
    However after the last couple of runs of only 10/15 miles I hear a high pitched whine when the engine is idling (don't think it was there before).
    I think the sound remains but the sound of the engine is louder so don't hear it when moving.
    Does this sound normal?
    I would appreciate any feedback on this.
    Thanks.
    Active Member Markubis's Avatar
    Jan 2018
    NH
    Silly question maybe, but is it the fan?
    Apr 2019
    Jacksonville
    Quote Originally Posted by Markubis View Post
    I must confess I am totally non mechanical - it could well be - maybe you are supposed to hear it - I really don't know.
    Apr 2019
    Jacksonville
    Quote Originally Posted by Jaxfann View Post
    Yea - temperatures down here are in the 90's so I guess if I start it cold in the morning and don't hear it that is probably what it is.
    Thanks
    Jan 2018
    NH
    I know that when I leave mine idling for a while after a ride on a warm day the cooling fan kicks on and its kind of noisy if you're not expecting it. It stays on after you shut of the Ryker. Not sure if that's the noise you hear though.
    Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I hear the same with my Rally. It is not the fan; that is a separate noise. What I hear is similar to the whine of fluorescent lights or a transformer. I have assumed it is the fuel pump or perhaps the magneto.
    Default Little checking.....
    if it is constant and not affected by the rpm's more than likely it is the fan thought should only run till the temp is back in check. Not familiar with the Ryker but most are that way....
    ​2012 RS sm5
    Active Member Aufgeblassen47's Avatar
    Apr 2019
    Ft Pierce/Lk Placid
    I've never heard mine come on yet.
    Apr 2019
    Jacksonville
    As the noise stopped after engine shut off I don't think it is the fan.
    The sound is similar to the one Tslepebull hears.
    I started Ryker 600 up this morning - temps in the low 80's - and drove 30/40 mph for about 10 miles - no sound until towards the end when I started to hear it very faintly.
    Trike running well so I am not too alarmed - will have it checked at 1,000 miles when I will have the oil changed.
    I appreciate your responses.
    Active Member poli's Avatar
    Feb 2019
    East Texas
    Quote Originally Posted by Aufgeblassen47 View Post
    You really to have your hearing checked then.
    Spyder RTS
    Ryker Rally
    Active Member mikeyuberalles's Avatar
    Feb 2019
    Clearwater, FL
    General consensus is fuel pump whine. A lot of people (including myself) just started hearing it within the last few weeks.
    Apr 2019
    Jacksonville
    Quote Originally Posted by mikeyuberalles View Post
    Thanks - do I assume not an issue other than the whine?
    Feb 2019
    Clearwater, FL
    The jury is still out. Some folks have been told by their dealers that it is normal, (which seems odd to me. If it was normal why would it suddenly start after 2 months).
    Other have gotten new fuel pumps.
    For now, I'm waiting it out and will bring it up when I get my 3000 check-up if nothing get worse. Oh, I did just switch back to premium gasoline to see if that makes a difference.
    It's going to be raining on and off all week, so I probably won't get much riding to see if the gas makes any difference.
    Apr 2019
    Jacksonville
    I am using premium gas.
    May 2019
    Tucson
    If I were to guess, after a few miles and enough bouncing, the fuel pump could move or settle in and the sock or some part of the assembly may now be hitting the tank. That and/or they are just noticing it when the tank is running a bit on the empty side and acting like an echo chamber. It is right infront of you after all.
    Dec 2016
    Georgia
    I just heard the whining today. It was hot--about 88 degrees in GA. I'd been riding about 25 minutes when I heard it at a stop light. I heard it at the last couple of lights and in my garage when I got home--the noise stopped immediately when I cut the power. Definitely not the fan--I heard the fan kick on at one of the lights. I'm guessing it's related to the high temperature and the fuel pump. I'm not worried about it but will keep an ear out. I've only ever put premium fuel in mine.
    Active Member bcraig's Avatar
    Apr 2019
    Grove City, OH USA
    Quote Originally Posted by Azbronco View Post
    A few days ago I experienced this too. Seemed to be coming from the area of the gas tank. I only use premium gas too. I shut it down when I got home and then started it right back up and the sound returned. I shut it down and waited about 30 minutes and when I started it up the noise was gone. I probably had about 150 miles on the tank at the time, so I'm thinking it had something to do with tank pressure and venting. I filled up shortly after that and haven't heard the sound again. I'll see how it goes when it gets low on gas again.
    Apr 2019
    Kansas
    I usually hear whining when I get home from a ride, it's my wife.
    Nov 2018
    N.E. Ohio
    now that was funny. cueman
    Apr 2019
    Kansas
    She's a keeper though, why? I can't get her to leave.
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    I happened to be out in the garage one evening and heard a whine under the wife's late-model toyota. After a bunch of research I discovered that it's supposed to do that. The fuel injection pump cycles 4 hours after the engine is shut off, something to do with purging the evaporative emissions system?
    Aug 2017
    New York
    May 2017
    Mesa, Arid-Zone-A
    The fuel pumps in the RTL are noisy..... at least mine is. There have been many discussions about this on the forum. Some have had replacements done and some live with it as I do. Doesn't seem to have any effect on performance or longevity of the pump. Just irritating. Probably the same pumps used on the Ryker.....? Jim
    Platinum Silver Satin 2014 RTL, SOLD
    Sep 2017
    Durham,Maine
    Quote Originally Posted by KC61 View Post
    Oh your in for it!!!
    Nov 2018
    N.E. Ohio
    Quote Originally Posted by bcraig View Post
    I heard my Rally doing a vent type of noise at each idle yesterday. I think it has some thing to do with tank venting also. I describe it as a single tone whistle. Let’s get to the bottom of this. cueman
