cruise control
New to the spyder thing. Can somebody tell me what models come with cruise control. THANKS
Mine is a 2016 F3 T and it has cruise control
On all new Spyders, I believe all RT models and F3T and F3Ltd. F3, F3s and Daytona I am not sure. Bruce
New to Sue and I
Gone but not forgotten
RTS 2011 SM5, 95,000 miles
Know it is NOT on the Rykers, Spyders yes every Limited model & most others. Other options to consider when shopping eco mode only on in ones with the 1330 (‘15&up)& trailer mode for the older 998
Most of the RS, ST, and RT Spyders have the Wiring and Sensor for the cruise control.
Only the mid and top level Spyders have the Right Side control module with the Cruise switch wired and functional.
Do a search for cruise control. Several riders have installed the needed switch as a DIY project.
Does not work on 2008 to 2012 GS/RS models.
See post #15. & #20.
https://www.spyderlovers.com/forums/...uise%2Bcontrol
Printing the cruise control knob.
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
Having just been shopping for the lower end of F3 Models they all do except the BASE F3 Does Not
Yep, at least 2019 F3 s and up all have cruise control as standard.
"Friend to those who have no friends. Enemy to those who need no enemies. Headache to those who have no aspirin."~ The Phantom Texter
2019 F3 s , Neutrino Aurora Accessory Fuse Block Blue
According to Can Am's SPEC sheets, it appears that only the F3 (base) does not have cruise control. All other models do have cruise control.
Mine has cruise control and it is functional. 2019 F3S.
2019 F3 Ltd
And it works great, I might add
Thanks for all the feedback...............
Throttle lock aprox. 10 bucks ebay.....Homemade stop pin. Its not a crui006.jpgse BUT It works great for restin ones hand. 011.jpg002.jpg005.jpg
The module for the F3S can be added to the base F3. I'm planning to have it done in July or August since it will be too hot to ride then.
