Page 3 of 7 FirstFirst 1234567 LastLast
Results 51 to 75 of 156
  1. #51
    GreatFalls Montana
    I bought my '14 RT L new, I have about 30k miles and it now has a Dess code.
    I live in Greatfalls Mt, any suggestions?
  2. #52
    Quote Originally Posted by lightnin leeRoy View Post
    I'm lazy ….read my post #50, and or #26 … that's the easiest alternative …. Mike
  3. #53
    Jul 2019
    UK
    If you want I can guide you thru DIYing yourself …. not hard just time consuming because the FRUNK has to come off ( *********** is full of Hooey that it can be changed without re-moving the Frunk ) …. the Module is $135.00 last I checked & no BUDS is necessary ….. Mike
    Some folk are guilty of fake news. It certainly can be changed without removing body panels, I've done it.
    However, it is a good idea to relocate the DESS unit incase it fails again and you need easy access to it, so here's my suggestion: The old DESS is up on the frame above the battery and its connector hangs down and is easily reached and disconnected. Disconnect the cable, reconnect the replacement DESS and cable tie it to the top of the battery bracket. Leave the old one in situ, why would you bother removing it?
  4. #54
    Jan 2019
    Tenn
    Will there be anyone at the SPYDER RALLY in Maggie Valley. N.C. in Oct that can disable the DESS ?
    Roger
  5. #55
    GreatFalls Montana
    I left my Spyder sit at work overnight. I arrived the next morning, it started normal and has started everyday.
  6. #56
    Houston
    You need to get it fixed pronto. Once DESS errors once, it will get worse and leave you stranded somewhere.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  7. #57
    …… From what others have reported here, the DESS failure isn't usually catastrophic ie. total & complete failure..... it seems to be a progressive thing, but once it begins the end result will Total...… 3 to 10 or so re-starts, but eventually total failure is the out-come …… good luck …. Mike
  8. #58
    Dec 2018
    Long Island
    Quote Originally Posted by w6ada View Post
    Hi, been reading ours an hours of threads regarding the DESS and key Error problems. Is this an issue still continuing? I have a 2014 spider and it appears these issues started then. Can I be comfortable buying a brand new spider that I will not have this issue?
    To answer your question, w6ada, I would definitely purchase a new Spyder and not be concerned with the DESS issue.
    Based on my own experience, 59K combined miles from riding 2012 and 2015 RTL Ltd's, I have not had this, nor any other mechanical or electrical problem. This is not to say that DESS failure or a different component failure won't happen to me, but I am completely satisfied with my Spyder and do not dwell on what may happen. You should also know that the DESS failure does not happen to every Spyder, I do think it is a minority of bikes that suffer this failure. However, it is good to know of potential problems, such as DESS failure, parking brake not releasing, compartment doors not opening properly, etc. so that if a failure does occur you will be able to address it quickly and knowledgeably.
  9. #59
    Quote Originally Posted by LongIsland View Post
    " Don't be concerned with a DESS failure " ………. I know of at least 75 failures and some multiple times ( and this from this forum ) ….. I hope it never happens to you …… but to suggest it is only a rare occurrence - well, I don't think they are rare and as far as I can tell BRP has not solved the problem …..Yet !! ……...good luck to all ……. Mike
  10. #60
    Aug 2019
    North Carolina
    Just a bit of clarification for me please.
    I just got a 2014 RT one week ago and have seen the orange screen come up twice. Each time I cycled the key off and then immediately back on and the bike started. Am I headed for failure ?
  11. #61
    Aug 2019
    knox tn
    Quote Originally Posted by petew View Post
    in my experience yes
  12. #62
    Aug 2019
    North Carolina
    Ok then , guess I'll be ordering myself one of 710004916.
    Fortunately I have to venture inside the bodywork to switch out my gps harness so I'll pull the frunk off at the same time and change out that module.
  13. #63
    I have pics in one of my albums showing where it is and where I re-located it to afterwards …. Mike
  14. #64
    Aug 2019
    North Carolina
    Thank you sir , I’ll have a look
  15. #65
    Vermont
    Yes,you are headed for a failure. I have a had the D.E.S.S module replaced twice ( both times under warranty, I have a 2014 RTS-SE6) and the ignition switch replaced once( under warranty).
    Get the D.E.S.S module replaced.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  16. #66
    Aug 2019
    North Carolina
    Deanna
    New one is on order ,should have it this week. When I do the install I will relocate it as BlueKnight911 did . Also plan to buy a back up and keep it with me if I travel.
  17. #67
    Aug 2019
    knox tn
    i went ahead and changed the antenna too on my 2015 rs,
  18. #68
    Aug 2019
    Dallas
    I'm going to get in on this so it's easier to locate later because we had this error the first time we brought our 2014 home but thought it was low battery. Maybe I should relocate as others suggested and keep a spare module with me?
    Tim
  19. #69
    Aug 2019
    knox tn
    Quote Originally Posted by Pictreed View Post
    Tim
    i found on mine when it quit for good i could raise the antenna and it would start every time, you can turn the ring under the key with pliars and pull it off and pry the antenna up higher without removing anything, and without damaging anything if you're careful, i had to get my antenna so high to start it you couldn't leave it that way though. just something to get you home.
  20. #70
    Nov 2013
    Oro Valley Arizona
    Mike did you get this from the factory or discover it yourself? I have been lucky so far and hope I will never have to try this. It is an interesting concept though.
    Has anyone heard how Bob Denman is doing?
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
  21. #71
    Quote Originally Posted by jaherbst View Post
    ..... Has anyone heard how Bob Denman is doing?
    Jack
    That's just a bit off topic Jack but the latest news is here: https://www.spyderlovers.com/forums/...e-w-Bob-Denman
  22. #72
    Jack
    What Mike are you referring to ???? ...…… ( Mike aka BLUEKNIGHT911 )???? ………...…… Mike
  23. #73
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by bayoubill View Post
    Hi Bill,
    I got the key ring off easy enough ( just a 1/8 turn to the left and it comes right off) BUT---- is the antenna the silvery ring around the opening for the key?????? and how did you pry it up????
    Thanks, Lew L
    2014 RTS , Circuit Yellow
  24. #74
    Sep 2014
    USA
    The antenna is a black ring around the key switch and can have resistance when trying to move it. There are also a couple of tabs that it seats into around the ignition switch.
  25. #75
    Aug 2019
    knox tn
    go to thread " Comfort Impossible for a RSS? "in post 25 the left pic of switch the antenna is the ring on the botttom of the pic that has a wire going to it, you can see the tabs on it and the knobs it slides down over, the top ring that turns holds it on
