Shell Rotella T6 5W40
FlyBoy2121
Mobil 1 10w40 motorcycle oil, changed each 5000 miles. Other than the oem oil used for break in miles, it has been Mobil 1 every oil change.
Ran aftermarket oil filter and O rings once and will be going back to oem oil filters and o rings.
Never accomplished SOAP samples to evaluate the oils long term durability, but others have and it does very well. 5000 miles is changing prior to the oil truly shearing from use. My concerns of wear are not in regards to the engine, but rather the gearbox.
Shared sumps are hard on the oil. Not worth the wear associated with long oil change intervals, and overall, oil and a filter is inexpensive vs gearbox wear.
I switched over to the rotella t-6 and one of the things that is very noticable is that if I don't let my engine warm up in cold weather and just try to start and go on my way the engine wants to stall on initial take off in first gear until the oil warms up.
I didn't have this issue with using the xps oil.
2020 F3 SE6
Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
Tackform Center Mount Phone Holder w/ rapid charging USB-C.
I heartily second BajaRon's recommendation of Blackstone doing the oil analysis. Get a baseline done then send out at every oil change. It is cheap insurance.
BTW I would change the oil and filter every 5000 miles or at least once a year if bike isnt used that much. As someone mentioned earlier in the thread, oil is cheap, engines are expensive....
2024 RT SEa To Sky ( back at dealer again due to blank screen issues , loss of BT and WIFI :-( :-( .. looking forward to the BajaRon event May 1-5 just with 2023 S2S only)
2023 RT Sea to Sky Shadow Green ( guess what NO errors at all in 9 months of owning....)
bel-ray exs synthetic ester sae 10-40 9300 miles or so changed oil 3 times this year havent changed orings at all did up grade to magnetic drain plugs what a time saver they are
Tags for this Thread
