Results 26 to 50 of 56
  1. #26
    Mar 2011
    Pence, wi.
    Ron, what weight and exact AMSOIL do u use? Can u post a pic of the bottle. Thanx Rhino
    2022 Spyder RTL- Chrome , Larger brake pedal Deep Marsala Red
  2. #27
    I'll add to this old thread. Go to https://www.spyderlovers.com/forums/...47#post1682047 to see the latest oil analysis for my RT.
  3. #28
    Mar 2021
    Maryland
    Walmart is selling 1 gal 5w/40 full synthetic Rotella T-6 for $23.48 . ..... Mike .....check Tractor Supply they often have Rotella coupons ( 2.5 gal $60.00 )....
    Just picked up some at Walmart for my next change, they have the T6 15w-40 2.5 gallon on sale for $56.00. covers me not only for this oil change but the next one too!
    https://www.walmart.com/ip/Shell-Rot..._LIA&gclsrc=ds
    2020 F3 SE6
    2020 F3 , Black
  4. #29
    Quote Originally Posted by rhino1 View Post
    Amsoil MCF 10/40 is what we use and recommend. Some that run in triple digit temps go with the 20/50, which is not a bad idea. In my opinion, the 10/40 is a better viscosity than the 5/40 that BRP recommends. I've detailed why elsewhere so I won't bore everyone again with it. I also feel that a 'Blended' oil is more marketing than it is value.
    BRP recommends what they sell. And though they used to sell and recommend their 10/40, they don't have that viscosity anymore.
  5. #30
    Vermont
    Quote Originally Posted by kentshaf View Post
    This is my first Spyder. I plan to take it to the dealer for it's first 3000 mile checkup. I am wondering what frequency others change their oil and what oil type? I have used full synthetic on my last couple of crusier motorcycles.
    Hi kentshaf,
    Change the oil in your spyder per the owners manual.
    Also, change the oil before you put it into winter storage. The oil can produce combustion by products that can harm your engine during long-term storage. I noticed that you are from Grant MI.
    Here is another idea, put fresh gas and stable in the gas tank before you put the spyder into hibernation.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  6. #31
    Durham,Maine
    And to think this thread started back in 2019!
    Last edited by Peter Aawen; 08-18-2023 at 03:37 PM. Reason: Your post was made today, the thread started in 2019! ;-)
    2012 RTL , Pearl
  7. #32
    Clinton, MS
    There is no statute of limitations regarding a post reply.
    Last edited by Peter Aawen; 08-18-2023 at 03:37 PM. Reason: Fixed quote display ;-)
    2019 RTL Phoenix Orange
  8. #33
    Dec 2018
    Long Island
    At minimum follow the schedule in your owner's manual. Both the type of oil and the oil change frequency schedule is in the owner's manual which can be found on the BRP wepsite. Page 112 starts the maintenance schedule, page 113 has oil change frequency; page 164 provides the oil specification. Ride Safe.
    Current: 2022 RTL SE6 Red Marsala and 2012 622 Trailer Lava Bronze,
    Previous: 2014 RTL SE6 Black Currant - 58,746 miles,
    2012 RTL SE5 Lava Bronze - 19,675 miles
  9. #34
    Aug 2020
    Niagara Falls NY
    Exactly the recommended interval, Valvoline 5-40 full synth euro and a brp filter. Also installed Lamonster magnetic plug. Runs and shifts great.
    Vince F in Niagara Falls
    2022 Spyder F3 Special Edition
    2020 Ryker Rally, sold
    2022 F3S , Stock Lamonster black diamond Monolith Black Satin
  10. #35
    Ah! But the subject matter started at least by the 17th Century BC when the Egyptians used olive oil to lubricate the movement of large stones and other heavy objects. I'm sure they were arguing about which brand and viscosity was best, even back then.
    Which just goes to prove that the old saying is true. 'There is nothing new under the sun'.
  11. #36
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Vincef329 View Post
    I could be wrong but I don't think Euro is the right Valvoline to use. I think you need 4 Stroke Motorcycle oil full synthetic, It comes in 10w 40 or 20w50. The motorcycle oil is wet clutch specific. The Euro is a European car oil and may not work in wet clutches.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  12. #37
    Florida Swamp
    Method of extracting 10W-40 Olive Oil posted in cartouche on Egyptian Tomb.
    2019 F3-S , Black & Silver
  13. #38
    Dec 2020
    Hartwell, Ga
    I could be wrong but I don't think Euro is the right Valvoline to use. I think you need 4 Stroke Motorcycle oil full synthetic, It comes in 10w 40 or 20w50. The motorcycle oil is wet clutch specific. The Euro is a European car oil and my not work in wet clutches.
    I just looked at the spec sheet myself. I think "if" it were mine that I would drain it out and replace it with an approved oil.
    Attached Files Attached Files
  14. #39
    Clinton, MS
    Yep, no mention of JASO or MA2 on it. That does not mean that it would not meet those standards, but I would be concerned with so many other good choices out there.
  15. #40
    Dec 2019
    Land of Lincoln
    Euro style oils typically have better HTHS numbers (high temp/high shear) and high calcium levels for extended drain intervals.
    Both of what you want in a common sump/gearbox. Leave it in, it's fine.
    Lots of discussion on car vs. MC oils. When you analyze them, many are splitting hairs. The difference between Mobil1 car oil and MC oil is a bit more Z and P, and about 7PPM less moly in the MC oil. Both are, for all practical purposes, interchangeable.Wet clutches slip and glaze because of spring tension in the clutch basket or other mechanical problems, not because of oils.
    I just bought a stash of 10w40 Havoline conventional for future changes because those weights are becoming less and less popular with the auto crowd. It was on closeout, and can't beat 2.00 a quart now. The trend is going thinner, there are now some 0w8 offerings for cars. I'm not worried in the least putting a conventional, auto oil in the Spyder for the next season.
  16. #41
    Mar 2020
    Richmond
    Shell Rotella® T6 5W-40 Full Synthetic Heavy Duty Diesel Engine Oil, 2.5 Gallon $56.00 at WalMart
  17. #42
    Quote Originally Posted by carbonation View Post
    I'm hyper FRUGAL, but I wouldn't take his advice..... if the oil doesn't have a Jaso MA II rating it's NOT going in my Spyder - PERIOD ..... good luck .... Mike
  18. #43
    Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    Quote Originally Posted by ekusafetyman View Post
    Yep! I can use this in my Ram Cummins 6.7, and the ACE 1330. Win Win.
    Retired U.S. Coast Guard 76-97
    Shad bags
    Lamonsters 2.0 usb dual power plate
    F3 ultimate boards
    LED arc lights
    Lidlox helmet extender
    Lamonsters top cuff with Ram ball and phone holder.
    Lamonster billet sway bar end links
    BRP driver backrest
    LED Volt meter
    BIW Cat Delete pipe
    Route 129 windscreen
    2022 F3S , Monolith black
  19. #44
    Mar 2017
    Ledyard Ct
    Agreed. I use Amsoil and have used it for all my bikes. Would not use anything else.
  20. #45
    Northern Kalifornia
    Gotta love these endless oil threads. Here's the best one I've read yet. Got it off of FB. I think I might try it and then send it in for analysis. LOL
    "I use waste oil from the local take out food store. It' full syn veg based oil cost nothing just filter it though an 'old' sock and away you go. Saves the environment as well."
    If you do this before I do let me know how it works and let us know if you feel an increase in HP also. Some say helps with those of us who complain about noxious fumes and gives your exhaust the slight odor of french fries. Stay safe out there and protect the environment.
  21. #46
    Workable, but maybe not economical, to use such oil for fuel but I sure wouldn't try it for engine oil!
  22. #47
    Waste cooking oil works fine if you're using it as fuel for an old-style mechanical pump type diesel engine, I know of vehicles that've done hundreds of thousands of miles on nothing but waste cooking oil from the local fish'n'chip shops!! Even run a few diesel engined vehicles on it myself.
    Mind you, it's not so good for the more modern electronic injector pumps &/or common rail diesel engines, but there are some who still do use it.... .... mostly just for a short while, tho! Doing that can get very expensive very quickly! . But there are 'bio-diesel' alternative fuels that work quite well for those more modern diesel engines.
    Still, I'm pretty sure that I'd never risk using waste cooking oil, fully synthetic or not, as engine or transmission oil in a diesel OR in my car/truck/Spyder tho - not even if it was run thru a better filter than an 'old sock'!!
  23. #48
    Dec 2020
    Hartwell, Ga
    Not sure about an engine oil but, it works great as a chainsaw chain oil. When I'm cutting wood that I plan to use in my smoker, I use cooking oil.
  24. #49
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    Like Mike said Walmart is selling 1 gal 5w/40 full synthetic Rotella T-6 for $23.48 . .........check Tractor Supply they often have Rotella coupons ( 2.5 gal $60.00 )....
    I change the oil every 5K miles, and use the Rotella T-6 ( I do ride in the winter so I don't change the oil untill the spring untill hit the 5K mark).
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
  25. #50
    INDIANA, USA
    ....Well you can use any oil that has the correct Specs stated by BRP.
    Soooooo..... I have been using Mobil 1 Motorcycle for my Spyder. I use the 10w40 which is a 'Full Synthetic Oil'.
    Like others have said, BRP used to have and sell a 'full synthetic' 10w40 oil for our Spyders. Now they don't offer this any longer. They have gone to a 'blended oil'.
    So now you know the 'rest of the story'. .....
    ENJOY YOUR LIFE WITH A SPYDER
Tags for this Thread
