Results 1 to 12 of 12
    Apr 2017
    Queensbury, NY
    Default Cleaning Under the Front Lip of the Frunk Cover?
    On my F3-T, the front lip of the frunk cover (or just below it) catches tons of bugs and debris. It's a tight squeeze to get in there, so I'm open to any suggestions for getting it cleaned up. Perhaps there's a thin, soft brush that someone could recommend to get in there without damaging the paint?
    Or perhaps a different idea?
    Thanks!
    Bert
    Bossier LoUiSiAna
    One of those gutter cleaning wands pointed up? watch where you point it!
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Sep 2016
    Chillicothe, Oh.
    Hydrogen Peroxide from your medicine cabinet to soften the bug guts. It won't harm the paint. Small paint brush, tooth brush, or Q-tips. I have a couple of 1 inch paint brushes in my "cleaning kit" that work great for getting into hard to reach spots. Trim one of the brushes back a bit and it makes for a stiffer brush, but still soft enough to be safe on the finish.
    2015 RT , Black
    Apr 2017
    Queensbury, NY
    Quote Originally Posted by Navydad View Post
    Thanks! Will give it a try.
    Bert
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    Quote Originally Posted by newbert View Post
    Thanks!
    Maybe I'm reading this wrong, but why don't you simply open the frunk lid all the way. The front lip is then fully accessible for cleaning. I use a microfiber cloth, works well
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    Mar 2017
    Quote Originally Posted by LifeLongRider View Post
    I wondered that too. Just open it. I have a burned out signature light there and when the bike is on, it lights up the frunk too when it works.siglite.jpg
    Apr 2017
    Queensbury, NY
    Actually, this is incorrect. It's not like the hood on a car. The frunk's opening, when open, is on the windshield side, not on the front of the spyder. The gunk I'm talking about is on the front of the spyder (ie - the "hinge" of the frunk).
    Bert
    Nov 2012
    Pueblo Colorado
    DSCN2904.jpg Maybe if you post a pic of where you're trying to clean it will all become clear. The Frunk Lip is accessible when you open the lid... to clean around the grille area, just remove the 4 torque screws and watch for any loose spring clips and then you can use your detailing tools, fluids and a little elbow grease to polish away the grime and bugs...Let us know where you are trying to clean...
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Oct 2016
    Faribault, MN
    Lamonster Black Dymond Detailer and a microfiber cloth folded over and pulled through the groove like floss.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Aug 2018
    Florida
    Quote Originally Posted by AeroPilot View Post
    DSCN2904.jpg Maybe if you post a pic of where you're trying to clean it will all become clear. ..
    Geez . . I hope I'm not the only one confused . . .
    2019 F3 Limited
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Put some serran wrap over it before you go and then just peel it off. Bug are gone.
    Can Am 2013 RTL SE5
    Apr 2017
    Queensbury, NY
    DSCN2904.jpg .... The Frunk Lip is accessible when you open the lid... to clean around the grille area, ...
    Yup - you're right. My mistake. I never thought to open the frunk to get better access to the front lip.
    Quote Originally Posted by DGoebel View Post
    That combo worked great. Thanks!
    Bert
