Results 1 to 7 of 7
    May 2019
    kouts indiana
    Default What bluetooth devices will work?
    have a question about my rt spyder have adaptor in trunk and would like to get a blue tooth reciever so i can play my pandora through speakers on aux. bought one, not sure if its cheap but when i take off u can hear humming through right speakers with music playing. is there a certain type of bluetooth reciver i can get to eliminate that noise? ty frank
    Last edited by Peter Aawen; 06-01-2019 at 07:52 PM. Reason: Moved from Do's & Don'ts thread!
    Jul 2017
    Massachusetts
    Good luck with that. The radio on my Spyder doesn't receive stations very well and so I got a LOT of noise trying to use an adaptor. I finally just opted to use blue tooth with a Sena SMH10R on my helmet.
    2017 Can-Am Spyder RT
    Aug 2018
    north wis
    brp connect app on phone is only way to bluetooth direct to bike.Unless there is a ipod type of device that you can dwnld an app to ?
    Linden, CA
    Give me a call I may be able to help you with this problem
    Dave
    Quote Originally Posted by cobravip55 View Post
    Jul 2011
    Mitchell, Ontario, Canada
    What year is your Spyder?
    What you described should work and should not make any difference what BT stereo audio receiver you used. It just may be that the receiver you got is defective or there is something wrong with the wiring in your Spyder. Plug your phone in directly and see if this works or the problem still exists.
    2018 F3 LIMITED
    Active Member Ride2GetHigh's Avatar
    Jun 2018
    Nipomo, Calif
    As per my previous post about the "new and improved" audio/bluetooth from the firmware upgrade it's all possible without any other hardware.
    I turn on the Sena 5 on my helmet then start the bike. The helmet connects and the radio from my bike plays through the speakers in the helmet. I then turn on the blue tooth on my android phone and it connects to the bike. Now I have two choices. Fm radio from the bike to the head set or Pandora from the phone to the head set THROUGH the bike. It's a matter of hitting the blue tooth or FM setting on the display. And with the phone connected you can bring up your contact list on the display, make a call, answer a call what ever with the rocker jog dial. It's pretty nice now that it works the way it should......
    2018 Spyder RT
    Custom Pinstriping by Fastripe.com see video @ https://www.dropbox.com/s/5icsez0g0w...iping.mp4?dl=0
    18" floor boards
    Ram mount phone X holder
    Ram mount cup holder
    Apr 2019
    Ohio
    I use this bluetooth adapter on my 2012 RT to do just what you are doing:
    https://www.amazon.com/BK01-Bluetoot...11-spons&psc=1
    I mounted the actual receiver to the left side of the passenger, so my wife can skip songs she doesn't like.
    Sometimes I get engine and shifting noises through the right channel, I've found that positioning of the power adapter and usb power cable impacts whether or not I will pick up the interference. Also a slightly loose power adapter will cause this as well... at least in my experience.
