Results 1 to 25 of 27
    Active Member P.W.'s Avatar
    Mar 2018
    IA
    Default Factory brake light strobe?
    Hello all,
    How do I go about getting the factory brake lights to strobe when applying the bake? What do I need to buy? I really like that safety feature
    (2019 RTL)
    Tanks in advance!
    P.W.
    Mar 2018
    IA
    Would I be getting close if I went to Custom Dynamics? If so, what kit would I buy?
    Thanks for your time and help!
    P.W.
    Feb 2019
    Portland, Oregon
    I put this on my F3L. 3 shorts, 3 longs then on solid.
    https://www.banggood.com/20W-LED-Bra...r_warehouse=CN
    Jun 2010
    Las Vegas
    I believe that Custom Dynamics calls their modulator the Magic Strobe.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2018
    IA
    Ricz, Thanks for the info.! I do appreciate you taking the time in replying. But since I'm not that good at wiring things up I was looking for a kit that would maybe plug into the factory harness someplace???? Maybe they don't make such a thing??? Anyone else with any other info.?
    Thanks for your time and help!!
    P.W.
    Mar 2018
    IA
    I believe your correct..... But don't see on there site anything that fits an RT. But I certainly could be wrong....they have to make something for an RT........right?
    Mar 2018
    IA
    I JUST found this.....but it says it fits RT 2010-2016.....Would it work on my 2019......Anyone?
    http://www.hotspyderaccessories.com/...light-flasher/
    P.W.
    Bossier LoUiSiAna
    Not the triple play? That may be more HD style lights Rivico has a S.O.M.A
    (Stay Off My A) to add additional LEDs that modulate. Great on mine, got at Spyderfest ‘15 bargain https://rivcoproducts.com/shop/metric-bikes/somakit/ it allows for a mixed light pattern. Stock lights stay on while stopped & the LEDs will flash (constant or 5s depends on how you wire it up)
    Call Custom Dynamics. I have one of their Magic Strobes on my RT. You can adjust the pattern to what you want; works very well.
    Mar 2018
    IA
    Yes sir will do....I think that is what I need to do.
    Thanks P.W.
    Jul 2018
    Saskatchewan
    Mar 2018
    IA
    Custom Dynamics doesn't offer a kit for a 19..........I emailed them.
    But I found this kit it fits RT 2010-2016.....Would it work on my 2019???
    I looked at the CD web site and saw that they did not include the RT model and also looked at the Hot Spyder Accessories web site and sat the RT flasher they sell is made by CD and the price is about what I paid for mine a year ago so I called CD to ask, "What's up". The very helpful lady I spoke with said the RT model Magic Strobe was not selling so they discontinued it and HSA is probably just liquidating inventory. She also said they have a universal Magic Strobe but you have to tap into whatever bike's wiring harness which I and a lot of others are not enthusiastic about doing. The strobe HSA is selling looks exactly like mine. I would bet it will work with a '19 RT but why not give them a call, 800-843-5118. CD sells a lot of those 3rd brake lights that mount on the trunk lid but they only come in chrome finish which I don't like.
    Mar 2018
    IA
    Man thanks for going WAY out of your way I REALLY appreciate you doing that!!!!! I'll give them a call and see what they say about fitting a 19
    THANKS ALOT!!!!
    P.W.
    Mar 2018
    IA
    THANKS ALOT!!!!
    P.W.
    Mar 2018
    IA
    Well..... I ordered the one from HSA that fits the RT from 2010-2016 hoping it still is the same wiring harness as the 19.
    If not, you'll see it here in the for sale section.....
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    Check *******.Com for another option on plug and play strobe controllers for the brake lights. Works exceptionally well.
    Sep 2014
    USA
    I have not used this but it may work for this purpose and its cheap??
    https://www.superbrightleds.com/more...odule/195/845/
    Faribault, MN
    I'm pretty sure Reggie and company carry a plug and play product called Brake flasher module with plug & play OEM harness that requires no personal wire work, like soldering or anything.
    Since they're banned/blocked from being mentioned here. You might just search for that exact phrase
    I have it and many others do as well.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Mar 2018
    IA
    I did find this with your help....but it doesn't say what years it fits.....
    https://spyderboyz.com/product/brake...y-oem-harness/
    Thanks!
    P.W.
    Faribault, MN
    That's the one, I believe it's for all RT year models as that rear connector hasn't changed., but you could ask them.
    Safe Rides,
    IBA 70020
    Mar 2013
    Quote Originally Posted by P.W. View Post
    Thanks!
    P.W.
    That is the one I installed on my wife's 2018 F3L. I am sure it will fit and work on your 2019 RT.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    May 2016
    Shoreline, WA
    I've used this on 2015 RTL with 622 trailer and 4 quick, 2 slow then solid lights gets attention, fairly easy install. Inexpensive and works well.
    Active Member SteveandBelinda's Avatar
    Canton, MI
    GearBrake.com
    All is plug-n-play, No cutting of factory wiring. Depends on which one you want. Right around $80 They are great.
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Member WaynoJ's Avatar
    Mar 2017
    Mill Creek, WA and Surprise, AZ
    Hello all,
    (2019 RTL)
    Tanks in advance!
    P.W.
    I have one on my '18 RTL from ******* that works very well. $100, and basically plug-n-play install. 5 or 6 different settings to choose from.
    I think I am, therefore I am. I think.
    George Carlin
    '18 RT Limited Dark - Champagne
    '15 ST-S White/Orange (sold)
    '14 Ducati Monster 1200 (rear-ended)
    '12 Triumph Street Triple R (sold)
    '99 BMW R1100S (sold)
    2018 RT Limited , Champagne
