Lamonster Fog Lights
Installed these last night. Very easy install and a quality product. Very bright and should help people see you. These combined with the LED Headlights I installed really light up the front end.
How long did it take to install and what sort of engine aptitude do you need to install?
Thanks,
Jim
I'm pretty sure Lamonster's page says that they only fit on the Rally.
Install was easy and yes supposedly they only fit the Rally, not sure why though. They mount to the top shock bolt on the Rally. It's all plug and play. All I removed was the hood and the left side panel to access the electrical plug. The only thing extra you will need is tome zip ties
Is there a switch to shut them off if you want?
No, you could add one if you want but there is not one included.
Originally Posted by KID Ryker
Is that two push buttons? Are they individually controlling the fog lights?
Got from eBay water proof switches. 1 is wired to my hood light. The other will go to fender lights. Almost the same switch as the BRP switch. The copper rings are just decorations.
I like it.
SpyderLovers Founder
Now fits All Can Am Ryker's.
We have added a longer bolt and spacer for those Rykers that have the spring facing up. These bolts and spacers are not needed on the Rally model unless you have changed the stock shocks.
http://www.lamonstergarage.com/can-a...kit-lamonster/
I put the Lamonster Lights on both our Rykers and I am completely satisfied with their looks and performance. They should come standard because they really increase your visability on the road to others especially during the daytime.. Thanks Lamonster!!!
I ONLY drive in daytime and they Do a Great Job of Increasing your visability to others.
Sea Doo GTI-SE 90 Jet Ski!!
do you have a picture with them on? thanks
Go the website and you can see pics of them.
Expecting to ride in fog?
Always
07390BBF-99A3-48D9-92C8-E302AEE1C8F4.jpgThey are super bright during the daytime in direct sunlight
LaMonster up graded the parts and they fit all Rykers, now. Just installed a set on my 600. They are awesome!
Don't get torqued over the fog light tag. They are running lights. Period. geo.
AND Bright In Daylight so your Front end appears much wider to oncoming vehicles. (I don't drive at night But they are Great for Daytime)
For folks that do drive at night are there any on/off photos with the fog lights that illustrate the beam coverage? We have deer and hogs in my area and a little more headlight range could be helpful.
