Results 1 to 22 of 22
    Kansas
    Default Lamonster Fog Lights
    Installed these last night. Very easy install and a quality product. Very bright and should help people see you. These combined with the LED Headlights I installed really light up the front end.
    Jun 2018
    Pa.
    How long did it take to install and what sort of engine aptitude do you need to install?
    Thanks,
    Jim
    Feb 2019
    Clearwater, FL
    I'm pretty sure Lamonster's page says that they only fit on the Rally.
    Kansas
    Install was easy and yes supposedly they only fit the Rally, not sure why though. They mount to the top shock bolt on the Rally. It's all plug and play. All I removed was the hood and the left side panel to access the electrical plug. The only thing extra you will need is tome zip ties
    Oct 2015
    miNNESota
    Quote Originally Posted by KC61 View Post
    Is there a switch to shut them off if you want?
    2019 900 Rally , Black
    Kansas
    Quote Originally Posted by vstrommer View Post
    No, you could add one if you want but there is not one included.
    Aug 2015
    Crosby,Texas
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by KID Ryker View Post
    Is that two push buttons? Are they individually controlling the fog lights?
    Aug 2015
    Crosby,Texas
    Quote Originally Posted by Markubis View Post
    Got from eBay water proof switches. 1 is wired to my hood light. The other will go to fender lights. Almost the same switch as the BRP switch. The copper rings are just decorations.
    Jan 2018
    NH
    I like it.
    Springfield, MO
    Quote Originally Posted by mikeyuberalles View Post
    Now fits All Can Am Ryker's.
    We have added a longer bolt and spacer for those Rykers that have the spring facing up. These bolts and spacers are not needed on the Rally model unless you have changed the stock shocks.
    http://www.lamonstergarage.com/can-a...kit-lamonster/
    Oct 2015
    miNNESota
    I put the Lamonster Lights on both our Rykers and I am completely satisfied with their looks and performance. They should come standard because they really increase your visability on the road to others especially during the daytime.. Thanks Lamonster!!!
    May 2009
    Connecticut
    I ONLY drive in daytime and they Do a Great Job of Increasing your visability to others.
    Sea Doo GTI-SE 90 Jet Ski!!
    Jan 2019
    Indiana
    do you have a picture with them on? thanks
    Kansas
    Quote Originally Posted by ryker View Post
    Go the website and you can see pics of them.
    Ft Pierce/Lk Placid
    Expecting to ride in fog?
    Kansas
    Quote Originally Posted by Aufgeblassen47 View Post
    Always
    Oct 2015
    miNNESota
    07390BBF-99A3-48D9-92C8-E302AEE1C8F4.jpgThey are super bright during the daytime in direct sunlight
    OH
    LaMonster up graded the parts and they fit all Rykers, now. Just installed a set on my 600. They are awesome!
    OH
    Don't get torqued over the fog light tag. They are running lights. Period. geo.
    May 2009
    Connecticut
    Quote Originally Posted by Geo333 View Post
    AND Bright In Daylight so your Front end appears much wider to oncoming vehicles. (I don't drive at night But they are Great for Daytime)
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    For folks that do drive at night are there any on/off photos with the fog lights that illustrate the beam coverage? We have deer and hogs in my area and a little more headlight range could be helpful.
    2019 Ryler Rally , Shock Yellow
