Choice - 2017 Daytona or 2018 S
Have the choice between a 2017 F3-S Daytona or a 2018 F3-S for within a $500 difference (Daytona is more).
So does the 2017 Daytona have stuff the 2018 S does not besides being Yellow instead of just Black?
Thanks for the input.
Tim
Daytona has the graphics and yellow stitching,super sport grille,drag bars,rear seat cowl and gauge spoiler as extras.
Unless the 2018 F3S was a color that I couldn't resist, I would choose the Daytona, just to be different. It definitely gets a little more attention. Even though I am not a fan of the yellow.
choices, choices
it's a visual thing.... if they are both new with full warranty then it is what you like best. I am sure you can negotiate the difference on the daytona as it has been in their stock longer (if a dealer) and they may give you extras in warranty or acc to make it a better deal. Check them out and see the comfort etc even though they are both adjustable in that area....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
I thought it was mostly an appearance thing. Thanks for the clarifications.
Doesn’t the 18 have the digital dash? Also on the Daytona I believe you can turn the nanny down for a little more fun. I’d go for the Daytona as I’m not seeing that the digital dash is anything special.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
SpyderLovers Sponsor
Tim, test drive both of them. The Daytona is a bit of a reach, as the drag bars go straight across, and the S has some pullback. Yes, you can change anything, and make it fit you. Perfect timing - we will be in Spokane on 17 June. Bring the new bike up to get Squared Away!
Joe Meyer
The digital dash did not show up on the F3S in 2018. I do prefer the turned down nanny.
Digital dash is only on the RT, RT Limited, F-3T & F-3 Limited (all 2018 & up)
Cruzr Joe
