Results 1 to 9 of 9
    Jun 2015
    Boise Idaho
    Default Choice - 2017 Daytona or 2018 S
    Have the choice between a 2017 F3-S Daytona or a 2018 F3-S for within a $500 difference (Daytona is more).
    So does the 2017 Daytona have stuff the 2018 S does not besides being Yellow instead of just Black?
    Thanks for the input.
    Tim
    Very Active Member Cobwebs's Avatar
    Sep 2018
    Australia
    Daytona has the graphics and yellow stitching,super sport grille,drag bars,rear seat cowl and gauge spoiler as extras.
    May 2013
    Apex, N.C.
    Unless the 2018 F3S was a color that I couldn't resist, I would choose the Daytona, just to be different. It definitely gets a little more attention. Even though I am not a fan of the yellow.
    Default choices, choices
    it's a visual thing.... if they are both new with full warranty then it is what you like best. I am sure you can negotiate the difference on the daytona as it has been in their stock longer (if a dealer) and they may give you extras in warranty or acc to make it a better deal. Check them out and see the comfort etc even though they are both adjustable in that area....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jun 2015
    Boise Idaho
    I thought it was mostly an appearance thing. Thanks for the clarifications.
    Jun 2010
    Las Vegas
    Doesn’t the 18 have the digital dash? Also on the Daytona I believe you can turn the nanny down for a little more fun. I’d go for the Daytona as I’m not seeing that the digital dash is anything special.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2010
    Las Vegas, NV
    Tim, test drive both of them. The Daytona is a bit of a reach, as the drag bars go straight across, and the S has some pullback. Yes, you can change anything, and make it fit you. Perfect timing - we will be in Spokane on 17 June. Bring the new bike up to get Squared Away!
    Joe Meyer
    May 2013
    Apex, N.C.
    The digital dash did not show up on the F3S in 2018. I do prefer the turned down nanny.
    Bryant, Arkansas
    Digital dash is only on the RT, RT Limited, F-3T & F-3 Limited (all 2018 & up)
    Cruzr Joe
