Results 1 to 10 of 10
Thread: Horn issues
    Jul 2018
    Ellington New York
    Default Horn issues
    Has anyone had a problem with the horn not working? I have a 2013 Spyder RT-S. Horn quit working. Checked the manual to see which fuse goes to the horn, but found no info on that. Any suggestions?
    Jul 2011
    Mitchell, Ontario, Canada
    Right fuse box F5 20 amp. Also for the air suspension. What often happens is that the air suspension compressor has failed and causing the fuse to blow.
    2018 F3 LIMITED
    Jul 2018
    Ellington New York
    Thanks. Found the blown fuse and replaced it. Horn works now. We'll see if that takes care of it, or if there is a larger issue. Appreciate the help!
    Apr 2019
    Florida Swamp
    Horn not working would be a disaster. It is used to let the dog know I brought home some left-overs and she should meet me in the bike shop when I park.
    2019 F3-S , Black & Silver
    Jul 2018
    Ellington New York
    Ok, replaced the fuse and the horn worked...right up until I started the bike. Then it blew again. Now what? Can the compressor be replaced? Can I do it myself? Or can I just unplug the compressor?
    Apr 2019
    Florida Swamp
    Quote Originally Posted by RonR View Post
    Time to get out the multi-meter and look for the reason the fuses are blowing. A short somewhere or something is causing the fuses to blow out. Find it and fix it.
    Oct 2016
    Faribault, MN
    Had the same experience last year, disconnected the compressor and by-passed the normal compressor "plumbing", just running a direct line from under the seat to the airbag.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jul 2018
    Ellington New York
    Could you PM me with the details of how you did this? Thanks.
    Oct 2016
    Faribault, MN
    Just did.
    Safe Rides,
    IBA 70020
    Oct 2016
    Faribault, MN
    Ron, 2013 RT-S should use Relay R4 that would stop the leak down from the ACS Solenoid valve if you wanted to leave all original components in.
    Safe Rides,
    IBA 70020
