Results 1 to 11 of 11
    Jul 2011
    Vermont
    Default Spring disloaged in trottle
    UGH I completed putting my foam covers on my 2014 Spyder RT. Apparently I dislodged the spring in the trottle Tried to put bike back in garage and it froze up. I guess no riding for me this week-end. Is there an easy fix--I am not terribly adapt at taking things apart
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Phyllis View Post
    Maybe you could describe the symptoms more fully. Installing foam grip covers should not impact the throttle return spring necessarily.
    2014 RTL Platinum
    Why do you think it was / is the throttle spring ???? …. I have a 2014 RT and I actually removed the spring in the throttle so it is easier and less fatiguing ….. Even if yours is dis-lodged it should still work …. Mike
    Sep 2014
    USA
    Are they not Throttle by wire?
    Jul 2011
    Vermont
    Sorry--More info. After I had put the foam grips on, I was installilng the LidLox. When I did the throttle side, the spring was falling out.
    Mar 2018
    north georgia
    Mike hopefully not to sound ignorant, where exactly is the spring located? i, too find it tiring during a longer ride and have wondered about reducing the tension or removing, only problem is not knowing where it's located. thank you for you helpful information on the spyders
    Nov 2018
    Claremore, Ok.
    Are you talking about the spring inside the LidLox mechanism?
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Quote Originally Posted by whitedog43 View Post
    PM sent ….. Mike
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by Revalden View Post
    I thought the same thing, Revalden, because I can vaguely remember a spring hitting the ground when I installed my Lidlox. But when I just ducked out and removed one of them to see if my memory was correct, I couldn’t find a spring, so I gave up
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    I don't have LidLox or the foam grip covers, so this is only a guess. Is it possible that something in the LidLox was screwed in too tight and is preventing the throttle from rotating?
    To take pressure off my wrist when the cruise control isn't appropriate of safe there are a few product out there. I have used a narrow style Crampbuster on my Bonneville, and an original style Throttle Rocker (the version without velcro) on the Harley I had. I have a wide style Crampbuster on the Gold wing trike. Both brands of products do a good job of relieving the pressure and grip needed to keep the throttle on. There is a "improved" version of the Throttle Rocker that is held on by velcro instead of the tightness of the plastic looping around the grip. At one time the Throttle Rocker people did this to get around patent infringement of the Crampbuster, but it is back on the market. Curious thing is that if you go to either the Throttle Rocker or the Crampbuster website over on the top right there is a link to the competing product. Must be owned by the same company now. Here is a link to the Throttle Rocker, you'll notice a clickable Crampbuster logo on the upper right. https://www.throttlerocker.com/
    There was a thread "Crampbuster or Throttle Rocker" a while ago on SpyderLovers, here a link to it. https://www.spyderlovers.com/forums/...hrottle-Rocker
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Phyliss's issue has been solved …. She PM'd me …. She also removed the spring assembly at the end of the hand grip to lessen the tension ….. Mike
