Page 1 of 2 12 LastLast
Results 1 to 25 of 31
    Jan 2019
    Kansas
    Default General Altimax rear tire - how do you access valve stem??
    Hello,
    following the good advice of many forum members I just ahd my bike shop replace the rear tire of my 2014 RT with a General Altimax RT43. I like it a lot so far, but my problem is, how in the world do people access the tire valve? The stem is turned to the left side, towards the transmission belt and I see no way to reach it. What am I missing? Thanks!
    Feb 2019
    Portland, Oregon
    That valve requires a straight air chuck.
    Quote Originally Posted by gianfri View Post
    Hello,
    The info I orig. typed here has been removed by me - for reasons I won't mention ……. Do you know what the ' IGNORE " list is …….
    Dec 2015
    Oakley Utah
    Hello,
    There are many threads on the topic of rear wheel valve stem access on the RT. It has nothing to do with the tire that is mounted. Some of the solutions involve a different style of valve stem, but that involves demounting the tire.
    I adapted my Ryobi tire inflator to accept a different chuck, which makes it easier to inflate the tire. But, it's still a hassle. Fortunately, the tires hold the pressure pretty well and only need occasional attention.
    2014 RTL Platinum
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    This air chuck works perfectly.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Jan 2019
    Kansas
    Thank you for your reply. I managed to access the previous tire (stock that came with the bike) but I cannot reach this one, so there must be something different.....
    Dec 2015
    Oakley Utah
    In that case, it sounds like your tire installer replaced the OEM valve stem with something different. You might need to ask them to replace with the correct valve stem.
    2014 RTL Platinum
    Jan 2019
    Kansas
    So is the stem mounted on the rim, or does it come with the tire? Sorry, I am obviously very ignorant about this issues....
    Dec 2015
    Oakley Utah
    It's a tubeless tire (just like automobile tires), so it's mounted to the rim. It's very common for a tire shop to replace the valve stem at the time they replace a tire, but it's not at all necessary.
    Bicycle tires are different; they use inner tubes with the valve stem as part of the inner tubes.
    2014 RTL Platinum
    Jan 2019
    Kansas
    I knew it was tubeless, so it makes sense that the valve is on the rim. I am not sure why I find it more difficult to reach it now than before then. I will check with the installer to see if they changed the valve. Thanks!
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Bensonoid,
    Re: This air chuck works perfectly.
    I bought one of those a few weeks ago & agree completely.
    I put the valve stem at about 11 o'clock & have great access to it; both for checking the pressure & adding/removing air.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Jan 2019
    Kansas
    Quote Originally Posted by Bensonoid View Post
    Do you know where to find it, or the make and model? Thank you.
    Feb 2012
    Spring City,Utah
    Google "Harley Davidson valve stem extension". Harley has the same problem with their ultra glides. They have a nifty little extension that allows you to check or add air, I think it is 10.95 and is about 6" long. I have one and it works great.42300009__1__32209.1468872284.1280.1280.jpg
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jul 2014
    Mint Hill, NC
    Absolutely!!!
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    May 2014
    Beaverton, Oregon
    Hi gianfri,
    Re: Do you know where to find it, or the make and model? Thank you.
    I bought mine up the street at the local auto parts store.
    I suggest you print out the photo & take to it an auto parts store & see if they have one/can get you one.
    Jerry Baumchen
    2008 GS SE-5
    Dec 2013
    Was it a Dealer or workshop who pulled the wheel off your Spyder & stripped the drive sprocket etc ready for the tire to be replaced, and then re-assembled it all & replaced the wheel on your Spyder Gianfri?
    Any chance that when the wheel assy was removed from the Spyder & being stripped of the drive sprocket & cush pads, the sprocket's position wasn't marked or taken note of, so that once it came time to fit that back on, it could be put back on in the same position? If the sprocket is 'clocked' just a little, & then replaced on the wheel assembly in the wrong position so that one of its spokes is now hiding the valve stem, you probably won't be able to check the tire pressure once it's on the Spyder again?? It's certainly possible to do that, and once the wheel is back on the Spyder, if one of the drive sprocket spokes is located such that it hides the valve stem, it is damn near impossible to get to even WITH any of the handy devices mentioned above!!
    If that's what's happened, the rear wheel assy will need to come off the Spyder again to fix it, but at least the tire doesn't need to be de-mounted - just the sprocket & cush pads. Once the wheel is off the bike, you'll hafta pull the sprocket off and clock it correctly so that there isn't a spoke in the way of getting at the valve stem. Not massively hard, but certainly annoying to hafta do it. That's why I asked who did the wheel & sprocket remove & refit job?!? That someone is likely going to need to fix it!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2016
    Chillicothe, Oh.
    What Peter said.
    2015 RT , Black
    Apr 2019
    Greer, SC
    Absolutely!!!
    And they guarantee it won't leak oil for at least 3 days.
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    I find that a 2" long tubeless valve stem is much more practical (assuming that the spokes are aligned as Peter points out) as it is more flexible for easy access.
    The best substitute for brains & knowledge is....................silence.
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    You should be able to access it make sure wheel position is so that valve stem at bottom slightly to right and should be able to access it
    Jan 2019
    Kansas
    Ah! This is EXACTLY what happened! The valve is right behind a spoke. I can touch it, but there is no space to insert even a flexible extension tube. Back to the shop. Thank you!
    Dec 2009
    West Oz
    With a 2" valve stem you can access it. Just saying for a friend.
    May 2014
    Benson, NY
    I've had mine for so long I can't remember where I stol...bought it. I googled it to get the picture, they are quite common. I've seen a quite a few spyders that have had the pulley put back on in the wrong position like Peter mentioned. Everyone should take a picture of their rear wheel showing the valve stem in between two of the sprocket spokes to show your tech how to put it back together.
    Sena 20s
    Jun 2010
    Las Vegas
    We see that happen a lot and I always tell people to go back to whoever installed the tire and ask them to check the pressure because you can’t. Then make them re-clock the pulley for you.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jan 2019
    Kansas
    Quote Originally Posted by SpyderAnn01 View Post
    I went back to the shop and they were very nice about it. They took the wheel off and readjusted as needed. All is good. Thank you so much for all your advice! I don't know what type would do without this forum......
