2013 RTL with 660 GPS mount need a GPS
Bought a 2013 RTL that has the GPS mount on it but no GPS. Looking for a GPS I can plug and play with this set-up. What are my options?
Get on Ebay and find either a Garmin Zumo 660, or a Garmin Zumo 665 if you want the XM capabilities.
Jaap Kroes
Ham Radio Call Sign KR0ES
2014 Pearl White RTS SE5
My understanding is the 665 will not fit, different pin out at the handlebars. Good luck.
Bob, k7xi. 2013 RTL
I have the Garmin Zumo that came with my 2012 RT Ltd. that I traded back in October. I also have the carrying case for it. If you are interested, you can PM me with an offer.
Does any one know for sure that the 2012 Garmin 660 is plug compatable with the mount that comes on the 2013? Is there a place I can go to find out?
The 660 mount should be powered and is likely already wired into the Spyder. So all you need is the 660 Zumo GPS head unit and attache it to the mount. I am using the 590 that I switch between my bikes, but like the options of that unit and didn't feel the need to upgrade. Hope you like the Zumo. I have been using them since introduced way back in 2007.
Where does one find the mount if it is wired in??? I just got a 2018 and it looks pretty bare, unless the mount is under some of the fiberglass....
2 Wheels (ST1100, Marauder, Honda Shadow, Honda Rebel) 3 wheels (2018 Spyder RT Ltd)
Foam grip covers
Tri-Axis Handlebars.....
I don't believe it is wired into the 2018 RTs because you now have the BRP Connect,
Cruzr Joe
