Results 1 to 8 of 8
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Default 2013 RTL with 660 GPS mount need a GPS
    Bought a 2013 RTL that has the GPS mount on it but no GPS. Looking for a GPS I can plug and play with this set-up. What are my options?
    Can Am 2013 RTL SE5
    Jul 2017
    Leighton, IA
    Quote Originally Posted by wingit3611 View Post
    Get on Ebay and find either a Garmin Zumo 660, or a Garmin Zumo 665 if you want the XM capabilities.
    Jaap Kroes
    Ham Radio Call Sign KR0ES
    2014 Pearl White RTS SE5
    2010 RTS - SM5 , Stock Black
    Feb 2015
    Carson City, NV
    My understanding is the 665 will not fit, different pin out at the handlebars. Good luck.
    Bob, k7xi. 2013 RTL
    Active Member Spyder Insyder's Avatar
    Sep 2018
    Payson, Arizona
    I have the Garmin Zumo that came with my 2012 RT Ltd. that I traded back in October. I also have the carrying case for it. If you are interested, you can PM me with an offer.
    Dec 2016
    Does any one know for sure that the 2012 Garmin 660 is plug compatable with the mount that comes on the 2013? Is there a place I can go to find out?
    Can Am 2013 RTL SE5
    Mar 2019
    Southern CA
    The 660 mount should be powered and is likely already wired into the Spyder. So all you need is the 660 Zumo GPS head unit and attache it to the mount. I am using the 590 that I switch between my bikes, but like the options of that unit and didn't feel the need to upgrade. Hope you like the Zumo. I have been using them since introduced way back in 2007.
    Active Member hershey's Avatar
    Feb 2017
    Aurora Indiana
    Quote Originally Posted by wiggy1 View Post
    Where does one find the mount if it is wired in??? I just got a 2018 and it looks pretty bare, unless the mount is under some of the fiberglass....
    2 Wheels (ST1100, Marauder, Honda Shadow, Honda Rebel) 3 wheels (2018 Spyder RT Ltd)
    Foam grip covers
    Tri-Axis Handlebars.....
    Bryant, Arkansas
    I don't believe it is wired into the 2018 RTs because you now have the BRP Connect,
    Cruzr Joe
