Results 1 to 8 of 8
    Mar 2019
    Ky
    Default Tire inflation spec
    Maybe a stupid question, but the operators manual for my Rally does not specify tire inflation pressure. It says to refer to the tire label.
    Would that be the sticker inside the service panel (says 20psi front, 28psi rear) or the psi specified on the sidewall (44 psi max load on all 3 tires).
    I am at max load (430 lbs) for the trike but not for the tires. I installed a fobo and all 3 tires are 39-40 psi cold from the dealer, purchased about 2 weeks ago.
    Nov 2015
    Chardon, OH
    The sticker....always the sticker...it's vehicle specific.
    Doug
    ”Freedom is not a loophole”
    Mar 2019
    Ky
    All my life, never knew that.
    Well then my tires are significantly over inflated.
    Guess the dealer doesn’t know that the sticker rules either.
    Just some tire info ….. All tires have a Max psi …. you use this in conjunction with the load you are carrying for the vehicle ….. Most folks here go to Auto tires when it comes time to re-place your worn tires ….. Kenda tires are marginal at best …. they also have an unusually high percent of Defective tires and tires that fail …. Currently the best spyder tire being sold are the Vredestein Quatrac 5 model …. they have 16 inch sizes and even some tires ( aggressive winter tread ) for the rear of the Rally model Stryker ……. If you switch to Auto tires ( any brand ) I and others have found that 14-15 front and 16 psi rear ( for the Stryker models ) work best ….. good luck …. Mike
    Mar 2019
    Ky
    Thanks Mike.
    Saw a recent thread on this, not sure that there are options yet for the Ryker Rally. Hopefully that will change.
    Quote Originally Posted by KyBill View Post
    Thanks Mike.
    Tire options …. not from BRP ….. Kenda's are just plain JUNK …… Mike
    Buy a decent tire gauge so you can keep your sneakers at the pressure comfortable to your riding style and within the manufacturer's stated pressure range. The latter doesn't apply to auto tires on a Spyder.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Label is typically under the seat
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
