Results 1 to 7 of 7
    Very Active Member Flanker's Avatar
    Apr 2013
    Michigan
    Default F3-S R Shock Bolt Torque
    I hope to have my Stage 2 Elka R shock installed (finally) within the next couple of weeks. Anyone know what the correct torque spec (in ft/lbs) is for the upper and lower shock mounting bolts? TY!
    2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock, Shad saddlebags
    Aug 2018
    Thousand Islands
    Here you go, just had mine installed not too long ago.
    Tip: when you install it you got to play with the jack(up and down)so it aligns the wholes for easy uninstall/install.
    2015 Canam Spyder F3-S SE6
    Akrapovic Straight Shot Silencer #219400514
    Detachable Passenger backrest #219400703
    Gauge Spoiler #219400531
    Blue Ridge Windshield #219400746
    Hood stripes decal kit #219400711
    F3 Idler Pulley #219800431 / Lamonster roller upgrade
    Shad SH36 side bags.
    Bajaron SwayBar
    Elka Stage 2 rear shock
    Arc LED fog lights
    Lamonster F3 bar clamp with Quad-lock phone mount
    Foam Hand Grip Covers
    Tufskinz Peel & Stick Tank Protector Pad (Glossy doomed carbon)
    Apr 2013
    Michigan
    TY!
    Yea, I've watched a shock swap video on YT; to see how they propped the Spyder up---got my rolling floor jack and some 4 x 4 lumber bits ready to go.
    Thought it would be handy (and kinda nice!) to have some hot "umbrella girls" on hand to provide some shade for me to work in. Shot an E Mail to BRP to see about sponsorship and the umbrella "tech support"--------------------haven't heard anything back yet.......................odd??
    Mar 2019
    Hagerstown MD
    It is also recommended by BRP to change those nylon nuts. I imagine most people reuse them, but manual says to replace if removed.
    Aug 2018
    Thousand Islands
    They do call on replacing lots of bolts in general but as long as nylon is not stripped i re-use them.
    Bajaron SwayBar
    Arc LED fog lights
    Apr 2013
    Michigan
    I reused mine with blue loc tite torqued to 35ft/lbs per your first post. Thanks again!
    Aug 2018
    Thousand Islands
    Quote Originally Posted by Flanker View Post
    Hope you will enjoy it and will make a difference. It sure did for me.
    Bajaron SwayBar
    Arc LED fog lights
