F3-S R Shock Bolt Torque
I hope to have my Stage 2 Elka R shock installed (finally) within the next couple of weeks. Anyone know what the correct torque spec (in ft/lbs) is for the upper and lower shock mounting bolts? TY!
2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock, Shad saddlebags
Here you go, just had mine installed not too long ago.
Tip: when you install it you got to play with the jack(up and down)so it aligns the wholes for easy uninstall/install.
2015 Canam Spyder F3-S SE6
Detachable Passenger backrest #219400703
Gauge Spoiler #219400531
Blue Ridge Windshield #219400746
Hood stripes decal kit #219400711
F3 Idler Pulley #219800431 / Lamonster roller upgrade
Bajaron SwayBar
Elka Stage 2 rear shock
Arc LED fog lights
Lamonster F3 bar clamp with Quad-lock phone mount
Foam Hand Grip Covers
Tufskinz Peel & Stick Tank Protector Pad (Glossy doomed carbon)
TY!
Yea, I've watched a shock swap video on YT; to see how they propped the Spyder up---got my rolling floor jack and some 4 x 4 lumber bits ready to go.
Thought it would be handy (and kinda nice!) to have some hot "umbrella girls" on hand to provide some shade for me to work in. Shot an E Mail to BRP to see about sponsorship and the umbrella "tech support"--------------------haven't heard anything back yet.......................odd??
It is also recommended by BRP to change those nylon nuts. I imagine most people reuse them, but manual says to replace if removed.
They do call on replacing lots of bolts in general but as long as nylon is not stripped i re-use them.
Bajaron SwayBar
Arc LED fog lights
I reused mine with blue loc tite torqued to 35ft/lbs per your first post. Thanks again!
Hope you will enjoy it and will make a difference. It sure did for me.
Bajaron SwayBar
Arc LED fog lights
