Results 1 to 9 of 9
    May 2019
    Windsor
    Default Windshield center arm replacement
    I replace the windshield center arm on my wife's 2010 RT, and now the windshield wil not go up or down.
    Danbury Connecticut
    Quote Originally Posted by tflatt View Post
    There is a magnet on the opposite side of the shaft from the gear. It's used to sense the position of the arm.
    Did you re-assemble the unit and change the position of the magnet relative to the arm ?
    I hope you bought a billet arm from noboot, instead of the same crappy arm from BRP.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Nov 2015
    Chardon, OH
    First thought - the engine must be running.
    Doug
    ”Freedom is not a loophole”
    …. and to further complicate matters …. that magnet acts the same way that elevator - start / stop devices do …. they must be positioned correctly for the READER to sense where to position your windshield …………. 5 years ago when I built my own " windshield arm " I discovered this …. luckily I marked where the Magnet shaft arm was before I removed it ……...good luck ….. Mike
    May 2013
    Edmonton Alberta, Canada
    Marking the magnet placement before removing is the key!
    2014 RT-Ltd , Cognac
    Active Member noboot's Avatar
    Sydney Auustralia
    My guess as we have experienced this problem before is that you need to rotate the arm 180'
    May 2019
    Windsor
    Thank you for the info, I read the maintenance Manuel and watched the YOUTUBE video and nowhere did it say to make sure the RT was running. Thanks again.
    Sep 2014
    USA
    So it was the magnet or the RT was not running??
    Sydney Auustralia
    Sorry about that, I guess we assumed you already know that your RT windscreen arm wont function without the bike running.
    The simplest of things quite often catch us out.
    Cheers, nobot
