Results 1 to 8 of 8
    Active Member IHOP's Avatar
    Devine, Texas
    Default Will the 2018 Instrument Panel fit a 2014
    Will the 2018 T Limited Instrument Panel fit a 2014 RT Limited and be able to match the wiring?
    For God So Loved the world...
    Started 2014 with a 2013 RT-S SE5. Wrecked it April 2019 with a 200lb hog! I am Blessed because if that was a two wheel motorcycle, DPS said without a shadow of a doubt I would have been dead! Thank you Can-Am! The issue I had with GIECO is they told me not to take anything off the Spyder when I brought it in to their claims center because they paid it out as a total. I just had ELKA put on all around and over $7,000 in Farkle that I am having to replace all that I could have taken off the '13. Bought a 2014 with only 3728 miles! Love it! My therapy!
    Apr 2017
    North Central Florida
    I think the likelyhood of that working are a bit LESS than ZERO.
    …… and I don't think they are even the same physical shape …… good luck …. Mike
    Nov 2017
    San Francisco Bay area
    Somebody somewhere is going to give it a shot I bet but it may cost more than it’s worth!
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Aug 2013
    SF Bay Area
    The 2018 & 19's have a different radio and no CB capabilities plus builtin bluetooth. Really don't think it would be worth it to find out it won't work.
    2021 F3 Ltd , Magna Red
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    why would you want to? I understand the new one is so full of hiccups, that that's the reason I wanted a 2017
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Mar 2018
    Ontario ,way up north
    The question should be ,would the 2014 dash fit a 2018 .
    2018 RTL , dark blue
    Aug 2013
    SF Bay Area
    The new dash is very different and has more to add to the bike.
