Results 1 to 13 of 13
    Jan 2019
    Alberta, Canada
    Default Wiring for heated jacket.
    Can anyone direct me to the process to run the wire from the battery to under the seat to connect a heated jacket?
    I'm new to the Spyder. I have 2018 RT limited spyder.
    Thanks, my wife will be super pleased when I get this connected for her!!
    Gary
    Jan 2019
    Alberta, Canada
    Default wiring a heated jacket
    Need some help in how to "snake" the wire from the battery to under the seat for a heated jacket.
    I have a 2018 RT limited. Also brand new to the Spyder
    Thanks,
    Gary
    Jul 2010
    Las Vegas, NV
    Remove the mirror, wind deflector, side panel. Put the connection under the seat, then run the wires up to the battery. Open the battery compartment, connect the two wires to the battery. Button everything up, making sure no wires are pinched anywhere.
    Joe Meyer
    Northern Kalifornia
    Put a fuse in the line also.
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    The amperage of the fuse will be determined by how much heated geat you want to use.
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Northern Kalifornia
    I think I put a 15 in mine and I've run two jackets and charged two Sena 20s at the same time, and nothing has gone bad so far. My 1330 is charged by and alternator so that in itself helps a bunch.
    Feb 2012
    Spring City,Utah
    It should come with a pigtail to come from your battery. That should have an inline fuse of 15 amps.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member spyderfish's Avatar
    Jun 2014
    West Bloomfield, MI
    I believe the fuse is there to protect the wire from overheating. In home wiring, 14 gauge wire should have no greater than a 15 amp fuse, 12 gauge wire is 20 amp. I think 12 volt systems are the same.
    2021 RTL SE6 - Marsala Red Blackout
    BajaRon Nosway Bar
    Front CentraMatic Balancers
    Value Accessories HandleBar Riser
    Brake LED Flasher
    Customized SmoothSpyder Tensioner
    Phone Phang
    Smart Mount Backrest
    LaMonster Mirror Locks
    Hopnel Frunk Bag
    Ultraguard Cover
    Jan 2019
    Alberta, Canada
    Thanks Sounds easy enough now!!
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    I went a bit over what you seem to be thinking of, but I wanted more outlets and didn't want to mess with the Can-bus system. Made a post here: https://www.spyderlovers.com/forums/...ribution-block
    I ran the rider heated gear connection and just let it live under the seat, pulling it out by the glove box when I use it. The passenger connection runs to a knock-out where a wired intercom connection was under the rear of the left passenger hand hold on previous models.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    May 2016
    Shoreline, WA
    This might help with wiring and fuse selection.
    Attached Files Attached Files
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    I= E/R or Current=Volts/Resistance
    Watts=Amps X Volts
    Wattage from 12V does not equal the same as 120V
    AJ
    Quote Originally Posted by spyderfish View Post
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Sep 2018
    greensburg,pa
    I ran from the alternator under the seat!
    2018 RT-L , Blue
