Results 1 to 10 of 10
    Jun 2015
    Hampton Roads, VA
    Default CLUNK CLUNK CLUNK when decelerating - Now what!?
    Over the last about 48-72 driving hours I noticed a clunking sound when decelerating. It is in time with the front sprocket. Now it is radical noise when slowing down and when coming to a stop it's a fast clunk then slows. I was thinking oh great after all the money I sunk in this pit the transmission is gonna blow up. In the driveway, in neutral (no engine running) I can roll it fwd and rev and there is a loud "clunk clunk" as it moves. This leads me to think it may not be the transmission but something else.
    I did have the front pulley off last year to replace the GBPS sensor, it was fine with no red dust or cracked/broken grooves. Put it back together with a fresh bolt from cheapcycleparts.com, torqued to the higher spec. It shifts & accelerates smooth as butter. The clunking doesn't come to the back tire (no jerkiness) when it is slowing down.
    I am clearing out a space in the garage to jack it up and take the belt off to start with rocking the front pulley to see if there is a lot of play, then take it off. Looking at the drive system on cheapcycleparts (clutch plates out to front sprocket) I don't see what could wear down and and make a gap or something.
    It may be my imagination but I swear I hear same noise on all GS/RS on when it's moving, but it really quiet. Maybe whatever "moves" or has a gap just cracked or broke. Clutch basket maybe?
    I imagine some gear head has seen (rather heard!) this before and might know what it is I am praying!!
    Thanks!
    Steve
    Aug 2019
    WA
    Yeah. That same thing just happened to me yesterday. I just put up a post before I read your thread.
    Oct 2011
    Kalamazoo, Mi
    Check ALL the teeth on your drive belt!!!!!
    2018 F3-T
    2018 F3-T , Pearl White
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Quote Originally Posted by IGETAROUND View Post
    And check the teeths of the front and rear sprocket for a rock wedge in there.
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    Jun 2015
    Hampton Roads, VA
    Turns out it was the front pulley. Inspected it 6 months prior it was fine. After taking out bolt it wobbled on the shaft badly. New one installed, runs great now.
    Jan 2019
    Toowoomba Qld Australia
    Glad it's resolved. Thanks for posting the update.
    2014 ST-S , Cognac
    Active Member Bruiser37's Avatar
    Tucson Arizona
    Can An has not fixed front sprocked problen, it could fail again... should be checked every 3K miles or sooner.
    2018 RT Limited Spyder , Garmin Zumo GPS, Battery tender wire harness Show Chrome brake pedal extender Oxford Blue
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by Bruiser37 View Post
    Can An has not fixed front sprocket problen, it could fail again... should be checked every 3K miles or sooner.
    I have a '16 F3, low miles, and when I removed the panel to check the sprocket this spring, there wasn't "rust" showing outside, or anything on my fingers other than normal grime. Is there any other way to check, short of pulling the sprocket? If I do that, do I put anything on the new bolt threads?
    I've read about using Assembly Paste for the sprocket and have an order on the way "just in case".
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Aug 2012
    Central Coast, CA
    I wouldn't use assembly lube. I would suggest instead using a Moly paste. They are designed so that the carrier evaporates and it leaves behind the moly lubricant.
    2020 RTL SE6
    Houston
    You can check the front sprocket by lying on the floor with a flashlight and looking up at it. If its covered in red dust, its dead. If its still black, its likely fine.
    The moly paste (not moly lube) used on the splines (not the bolt) is not the same thing as assembly paste used in engine assembly.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
