Results 1 to 18 of 18
Thread: Push Pin Pliers
    Kansas
    Default Push Pin Pliers
    FYI, Harbor Freight has Push Pin pliers for under $10
    https://www.harborfreight.com/search...20pin%20pliers
    Ft Pierce/Lk Placid
    How do they work any better than just using two flathead screwdrivers?
    Mar 2019
    Oviedo, FL
    What would you use these for?
    Kansas
    Quote Originally Posted by Aufgeblassen47 View Post
    Yeah your right, these aren't any better than 2 screwdrivers tearing up the push pins
    Kansas
    Quote Originally Posted by Gsrodeo47 View Post
    A lot of automobiles including the Ryker use plastic push pins to fasten plastic panels. These pliers grab the center of the plastic push pin for removal of the pin. Some sell these on line for over $25, this is the same design for under $10.
    Feb 2019
    Portland, Oregon
    I have been using the HF ones and find them a lot less fiddly than screwdrivers. They not only grab the pin part easily, but I also pull the larger part with them, grabbing them at the meatier places.
    I bought them with a 25% off coupon. That makes me like them even more.
    Mar 2019
    Oviedo, FL
    I picked up a set of panel removers from amazon. The door panel remover works great on the Ryker body panels.
    When I last looked at push pin pliers several years ago the jaws on the HF pliers were so I bought a pair of Lisle ones because they had perfectly matching jaws. I agree the pliers are better than two screwdrivers.
    Sep 2014
    USA
    these pliers dont work well with the BRP push pull pins..Jaws are a bit big. I found a wide blade screwdriver works better . JMO
    I have no problem with the Lisle pliers although sometimes you have to orient the grooves in the pins better than they may have been on initial assembly.
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    Dang it. I paid twice as much from Amazon,
    2019 Ryler Rally , Shock Yellow
    SpyderLovers Sponsor
    Jun 2010
    Las Vegas
    Why would you need two screwdrivers when one does the job nicely?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Oct 2015
    Lynden, WA
    I use one small flat point screw driver.
    My HF pliers is clumsy to use.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    May 2014
    Benson, NY
    Thanks for putting this out there KC. I already have a pair of these and use them extensively on the spyder and my cars.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Sebring, FL
    Push pins are all over on motorcycles now with plastic panels, as most of us know that have been riding for any length of time. Anyone ever lose the little pin in the middle of that thing, no fun.
    Aiuto parts stores and Spyderpops have them; good idea to have some spares.
    Jan 2015
    southern WI
    One $2.00 small straight blade screw driver slips em right out. I've never used anything else.
    2016 RTS , Pearl White
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    DSCN2860.jpg or a paint can lid lifter works well; especially if polished with a sander on the curve so it levers the pin out smoothly
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
