Results 1 to 17 of 17
    Active Member P.W.'s Avatar
    Mar 2018
    IA
    Default After Part number for oil change kit?
    Looking for the kit with all the "o" rings, crush washers and the oil itself. for our 2019 RTL
    Can someone please give me the XPS engine oil change kit number?.... and or where to buy from.
    Thanks for your time and help!
    P.W.
    Durham,Maine
    I get my stuff from Bajaron! Good to deal with and very helpful!! Good luck
    2012 RTL , Pearl
    Here it is. 779249
    Default Little checking.....
    I get them online from ebay or amazon prime as they have better prices. Just search oil kits for your model and buy the ones with free shipping .
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Mar 2018
    IA
    Thanks!!
    Mar 2013
    Marion, Arkansas
    Please support our sponsors first. I get my kits from BajaRon and my Amsoil from him.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Mar 2018
    IA
    I just received my kit with everything I need. But it only came with 5 quarts of oil......I believe the 1330 holds a little more than that correct?
    Nov 2010
    Hanover Park, IL
    5.2 quarts to be exact (for the manual, a tad less for the automatic), however you should be in the normal range with 5 qts. It's up to you to buy the extra qt to top off. That's why I switched to buying from Bajaron, better pricing and better oil (IMHO), and hassle free ordering.
    Mar 2018
    IA
    Thanks for the info...... I appreciate it!
    P.W.
    Quote Originally Posted by P.W. View Post
    Not sure I'd sweat the 0.2 qt every 28,000 miles when you change the transmission filter on the SE6. The 1330 uses virtually no oil and 5 quarts will put you nearly full and well above the add mark.
    IMO, it's not worth diddling with anything more than 5 qt even until you change the HCM filter if you have an SE. Five qt will put the oil level right in the middle of the range on the dipstick when the engine is fully warmed up and you check the level per the operator's guide.
    Mar 2018
    IA
    Thanks for all the help!
    P.W.
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    Default BRP Oil Change Kit SE6
    219800356
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    Mar 2018
    IA
    Thanks for the info.!
    P.W.
    Aug 2018
    Thousand Islands
    BajaRon for any of your oil needs. Filters, orings, amsoil.
    2015 Canam Spyder F3-S SE6
    Detachable Passenger backrest #219400703
    Gauge Spoiler #219400531
    Blue Ridge Windshield #219400746
    Hood stripes decal kit #219400711
    F3 Idler Pulley #219800431 / Lamonster roller upgrade
    Bajaron SwayBar
    Elka Stage 2 rear shock
    Arc LED fog lights
    Lamonster F3 bar clamp with Quad-lock phone mount
    Foam Hand Grip Covers
    Tufskinz Peel & Stick Tank Protector Pad (Glossy doomed carbon)
    Greenville Tx
    5 quarts just will get you to the fill mark or the lower mark. It says to put 5 quarts then get your spyder to operating temp and add as needed. Dont overfill. There is a 17 OZ difference from the lower bubble and full.
    2017 F3 Limited
    Greenville Tx
    I recommend the Lamonster oil change kit. http://www.lamonstergarage.com/lamon...r-spectro-oil/
    2017 F3 Limited
