Results 1 to 12 of 12
    Nov 2017
    Daytona Beach, FL
    Default Brake lights flashing when bike is off
    Searched and could not see this issue on any forum: rode through nasty storm two weeks ago (I know...but we were on way home from escorting the Rolling Thunder traveling Vietnam wall) and I was told my brake lights were flashing hours later. It was parked and off, never had this issue before. Sure enough, it ran the battery down and required a jump off. No codes are coming up, hubby test rode and parked it, brake lights again flash when bike is off, no key in it. He checked and said the main relay is very hot. Suggestions? 2011 RTSM5, 22k miles. Thanks for this forum!
    Jul 2011
    Mitchell, Ontario, Canada
    Defective brake light switch or short is the wiring harness. The main relay has nothing to do with it. The brake light circuit is always on. Even with the key off.
    Nov 2017
    Daytona Beach, FL
    I have a feeling it's the wiring harness...sigh...thanks for the info!
    Nov 2018
    Waynesboro, PA
    one thought. Some people have added a large Brake pedal and the weight of that will some time be to much on an older brake spring. Some have had to add a seconded spring for the bigger pedal so the brake light will not come on by it self. See if your brake pedal has play in it, is it all the way back?
    2012 RTL , Brown
    Nov 2017
    Daytona Beach, FL
    it is...it is the original small brake pedal. This started after a hellacious Florida rainstorm!
    Nov 2018
    Waynesboro, PA
    Quote Originally Posted by GatorOdie View Post
    Ok just a thought if you do not have any back play then it is more then likely what billybovine said above.
    2012 RTL , Brown
    Sep 2009
    La Valle, WI
    The brake switch could be bad or sticking. I would check that. Spray with electrical cleaner.
    2018 F3 Limited , Oxford Blue
    Jun 2010
    Las Vegas
    Nasty storm = dirt on brake light switch
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Oct 2015
    Lynden, WA
    The OP stated the brake lights FLASH. When the brake switch
    is defective the brake lights are off or on not flashing.
    This makes me wonder about the emergency flashers.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Bossier LoUiSiAna
    Disconnect battery for safety till you can have bike tested. Just removing relay is not enough. You may need to let the hard to reach spots air dry (in the sun)few days at least if water did get in somewhere deep.
    Jul 2011
    That is a good possibility. Water by itself should have no effect on and of the systems.
    Jun 2015
    Hampton Roads, VA
    Just to toss out there - you said battery ran dead & brakes flashing. I assume when key off the brake lights were on. On the 2013's the brake switch is really close to the "2nd muffler", like 1/2" away and gets stupid hot and fails (sticks on). I had to kick the pedal many times to get it off. I wound up folding up muffler bandage tape into a thick wad and stuffing it between the muffler and switch - no more sticks. Not sure if the frame changed in 2013 to cause this. Just something to look for when you have it up on ramps
