Results 1 to 25 of 26
    May 2016
    Jacksonville, FL
    Default Not a Glowing Endorsement for LED Headlights...
    I purchased these LEDs on Amazon:
    I liked the looks and they have good ratings. I found that I had to trim the white locking ring a bit to get them to fit. The tab here needed to go.
    Once in, I do like the results. Low:
    High:
    Here's from the front comparing the OEM and LED:
    Francis
    Active Member h0gr1der's Avatar
    USA
    Ok, I'll say it. I'm confused. The title implies you're not too satisfied with the LED's, but the pictures seem to show more illumination for both high and low beams as compared to the stock lamps. Please expound a little more, I'd appreciate it. Alway looking for improvements.
    h0gr1der
    2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Roadster Renovations Vibration Damper*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard
    Active Member Aufgeblassen47's Avatar
    Ft Pierce/Lk Placid
    Quote Originally Posted by h0gr1der View Post
    Must be the LEDs on the left.
    Kansas
    Those bulbs show 50w per bulb, that may become an issue. I'm going to order these and will report back if my Rally comes in this week. These are only 25w per bulb. Put Beamtech's on my wifes Tiguan R-Line for fog lights and they look and perform great.
    https://www.amazon.com/BEAMTECH-Head...gateway&sr=8-2
    USA
    In the original post, if you expand the pictures they are clearly named as to which is which. To me the LED's look good, but I don't know. Maybe I'm missing something. 50 watts is about 4 amps assuming 12 VDC, less if you sue actual 13.5-14.5 VDC.
    h0gr1der
    Mar 2019
    Oviedo, FL
    I purchased the Katana LEDs and also had to file/sand the rings down about 1mm to get everything to fit properly. I’m happy with mine.
    May 2019
    NY
    In a week or two I’m gonna give the hikari H4 LED a try.
    Ft Pierce/Lk Placid
    Amps don't "compensate" for volts. Higher volts also means higher amps.
    MS
    Quote Originally Posted by Aufgeblassen47 View Post
    I always thought it was 50 / 12 = 4.16 amps vs 50 / 14.4 = 3.47 amps
    May 2019
    New Mexico
    Higher voltage results in a higher wattage, given a constant ohmic resistance. You can also figure wattage as amps squared x resistance.
    Ft Pierce/Lk Placid
    Quote Originally Posted by SuperG View Post
    Precisely. Probably 50 watts is based on 12 volts or nearly 12 volts when engine is off, so 50 watts is the minimum. If your voltage regulator is putting out 14.5 volts, your headlights are actually putting out 60.4 watts of light.
    MS
    Thanks for the correction. My sometimes old mind was looking at it the wrong way.
    May 2016
    Jacksonville, FL
    Sorry for the confusion, the title is due to having to trim the white ring. Was trying to warn anyone about installation issue of having to modify OEM part as it's not a straight plug-and-play.
    I am satisfied with the LED output.
    Francis
    Apr 2016
    Bloomington, Minnesota
    It would have been nice if the LED would have lit up the tree trunk, then there would have been a clear winner. Still, the whiter light usually gives better visibility, and it appears to draw quite a bit less power off of the charging system, leaving more power for other things.
    Ft Pierce/Lk Placid
    Quote Originally Posted by PapaHotel View Post
    I cannot image what "other things" could be on a Ryker!
    Nov 2018
    N.E. Ohio
    How about heated clothing or grips. cueman
    Mar 2019
    GTA, Canada
    The shape of the bulb's "head" and the position inside the headlight matters. You need a more flatter profile (from side) and you need to make sure that the lenght of the bulb inside the headlight is the same to the stock bulb filament.
    The design of the reflective lenses is always specific and what type of bulbs you use does matter (not just because of the mounting points).
    You have to make sure that the originating point of the light is in the same spot inside the headlight as the stock bulbs - otherwise you are changing the light pattern that is being projected. You change the originating point of the light, you change the angle at which the light is reflected and as such you change the light pattern.
    Based on what I see from your images, the LED bulbs you are using are not the proper ones - your light pattern has changed, also the "filament" part is too "fat".
    You probably need something more like this:
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    4 sided LEDs I find give a better light disbursement then two sided LEDs when put in lights not made for LEDs. Halogens have 360 degree light and most two sided LEDs don't give that 360 degree range. I have similar LEDs on my wife's F3L and it puts out really good light. I tried the two sided ones and they were horrible.
    Kansas
    I order the 2 sided and will report back when I get them installed. I bought the Beamtech H4 off of Amazon. Another member used these and said they were great.
    Mar 2019
    GTA, Canada
    Quote Originally Posted by bscrive View Post
    That's not entirely true... you most probably had the wrong lights - length or power...
    Here is a better explanation from a guy that know what he is talking about - I know is from the car industry, but headlight design has the same principle for motorcycles as well.
    Is a long video, but worth to watch it. Listen to his explanation on the types of bulbs and headlights housings.
    https://www.youtube.com/watch?v=DeaDrH0gXZk
    Active Member ChicagoSpyder's Avatar
    Chicago
    Correct!
    Nov 2012
    Ottawa, Ontario
    "That's not entirely true... you most probably had the wrong lights - length or power... "
    I got the two sided lights from a well know supplier of Spyder lights, so they probably looked into this.
    Mar 2019
    GTA, Canada
    OK then...
    Jun 2019
    Massachusetts
    I purchased the Beamtech H4 LED lights nd found the heat sink to be very large. Appears that the headlight reflector will need to be removed to install. Anyone else purchase the Beamtech H4 LEDs have the same issue?
    Jun 2012
    Nevada
    Quote Originally Posted by Roc87 View Post
    I installed the same LED's and it was a tight fit. I think the right side was the tightest, but I was able to get them installed without removing headlight assembly.
    They work great and really light up the road. I also have a modulator on them and you can see me coming half mile away. haha
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
