Results 1 to 25 of 38
Thread: Hand going numb
    May 2019
    Washington
    Default Hand going numb
    So i took a 150 mile ride today on my Ryker and after a short distance my hand was going numb not painfull but a real nuisance. I was thinking about trying some thicker foam grips or a throttle rocker https://www.amazon.com/gp/product/B0...R3PFM9Y5&psc=1 has anyone had this issue or used either of these products?
    Apr 2017
    North Central Florida
    Yes. Both help some people.
    Loosening your grip helps too.
    As does changing your wrist angle sometimes.
    Sep 2014
    USA
    Not sure about the Ryker but have used the larger Foam grip cover that helps the numb feeling.
    I know vendors on the site and else where sells a version foam grip.
    Active Member MonPaul's Avatar
    Feb 2019
    Central WI
    I know it can really take the fun out of a ride. This is what I have, it really helped
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I think some of the vendors here also carry them.
    May 2016
    Tombstone Az
    I had the same problem the foam grip covers fixed it.
    Very Active Member Lin's Avatar
    Apr 2013
    Somersworth, NH
    Yup, Got them on mine.
    Lamonster Garage has Amazon beat on price, too.
    http://www.lamonstergarage.com/foam-...ker-lamonster/
    2016 RT-S Special Series
    2016 RT-S Special , 2 tone black
    Jun 2019
    Florida
    Does anyone know if these are 7/8" or 1" handlebars? On my Harley I installed some ergonomic handgrips that were great when I took a straight ten hour trip, stopping only to refuel. Surely, after market grips can be used. I used these grips (Chinese knock offs).
    Jun 2019
    Arizona
    Quote Originally Posted by MonPaul View Post
    Interesting. How much longer can you go before your hand needs a break?
    Active Member njfishfan's Avatar
    Dec 2018
    New Jersey
    Just put a pair of Grip Buddies Lites on mine today....hope to get a long ride in this week and see if they help.
    Feb 2019
    Central WI
    Quote Originally Posted by Hentch View Post
    I noticed the difference right away, but that's because I got away from the "death grip" after putting on the new foam grips. I have carpal tunnel from my working days and feel anything from a tingling to numbness in my fingers. I think it also helps because the diameter you are gripping is now larger than the stock grips. If you are thinking about it they are cheap enough and since they just slide on you can always take them off.
    Jun 2019
    Florida
    Tight grip will cause this. Relax, and see if it helps.
    Quote Originally Posted by Insane View Post
    x's 10 ….. When I'm just cruising, I don't even grip the grips at all …. just keep both Palms with open fingers on the grips ….. in the Twisties I grip firmly …. but that at most is 10 - 15 minutes at a time ….. Mike
    Member Harry76's Avatar
    Jan 2019
    Indiana
    My GFs 900 was vibrating badly, she had trouble seeing in the mirrors and her hands going numb.
    I ordered a 12" X 13/16" piece of brass from McMaster Carr, cut it in half, drilled and tapped a threaded 1/4 - 20 hole in one end (to aid in placement and removal) milled a 1/4 inch groove halfway down the side to clear the pins for the grips and inserted it with some silicone adhesive to hold it in place.
    Each side has 6" of brass inside.
    It fixed the vibration problems and she can see clearly out of the mirrors.
    Quote Originally Posted by Harry76 View Post
    If Her 900 was vibrating badly ….. those weights are a Band-aid to the problem ….. I believe Her wheels are very un-balanced …. and the added weights are Now masking the Bad vibes ….However the vibes are still there and if not addressed will cause other issues / problems down the road. ….. good luck …. Mike
    May 2019
    Washington
    Thanks everyone for all your answers i ordered a pair of foam grips from lamonster garage, hopefully this helps.
    Feb 2019
    Portland, Oregon
    Foam grips, loose grip, wrists in line with forearm.
    Ft Pierce/Lk Placid
    The Caterpillar yellow o-ring works much better than rocker thingamabob and is cheaper to boot!
    Feb 2019
    England
    Hi dklehman I have throttle rocker and have set it around 60 / 70 mph so then on motorway or fast A road I can rest my palm on it and relax my fingers it's a big help . Bit hard to stretch over grip but a heat gun helps to open it more to fit over grip regards Nico 75
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    I have arthritis in both thumbs from years of computer work.
    I use both the foam grips from ****led and this from Crampbuster...
    https://www.amazon.com/Crampbuster-C...e%2C143&sr=1-3
    Actually, I lost the Crampbuster about a month ago and have been missing is "sorely"...ordering replacement today!
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Apr 2017
    Quote Originally Posted by MDLNB View Post
    I personally REALLY don't like that style of grips.
    They feel funny.
    They aren't any softer than stock; feels harder in fact.
    For anyone considering them, I suggest that you actually try them out off the bike just for feel before shelling out the $$$.
    Jan 2019
    Indiana
    Her vibration was from the motor buzzing just like they all do, we have ridden 3 of them and they each had buzzing in the handlebars as many bikes do.
    Many bikes come with weighted ends for this purpose.
    Jun 2012
    Nevada
    Lets face it, we need cruise control so we can rest our hands.
    Is there anything out there for the Ryker yet?
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    I've owned so many bikes I can't remember them all ….. NONE of them Blurred the mirrors, or made my hands Numb. … I gave advice based on what you posted...……..Glad the weights made Her happy ….. keep an eye out for any unusual tire wear ….. Mike
    Jun 2019
    Florida
    They feel funny.
    I have them on my Harley and these are very soft. The black rubber is hollow and cushions the hand, isolating your hand from the vibrations. Of course, these are Chinese knockoffs.
    Mar 2019
    Depoe Bay Oregon
    I agree, and having large hands and gloves to tight does not help. I only have one pair of gauntlet gloves that are large enough and unlined. They do make a difference. I also think it can improve with just getting used to riding and take frequent small breaks helps. I can ride 10 hours a day now, at first 1/2 was hard. Also cold makes it worse for me. Keep trying and you will likely find what works for you.
