Results 1 to 13 of 13
    Active Member RLS Exhaust's Avatar
    Mar 2019
    Waxahachie TX
    Default RLS Exhaust Ceramic coating Service
    RLS Exhaust will now be offering a new service .If your having issues with heat but don't want to hear all the noise associated with the cat delete exhaust .I have started offering a new service i can take you old primary muffler and i can media blast it and ceramic coat it were you can cool it down as much as 400 degrees !
    Faribault, MN
    Can you do this to a 2013 primary? And or would doing this to a Cat Delete be any benefit?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    2013 RT Limited, Pearl White
    Farkles too numerous to list
    See my Spyder Garage
    IBA 70020
    Sep 2015
    Awendaw, SC
    How about ceramic coating the header pipes? Do you coat the inside of the tubes or the outside only? The reason is the tubes themselves would last a lot longer if protected from the heat, hence a coating on the inside would be better than the outside.
    Mar 2019
    Waxahachie TX
    yes i can and all my cat delete pipes are also coated .I do not have one available for your bike but i can ceramic coat your primary muffler.
    Mar 2019
    Waxahachie TX
    it would be and option i could coat the inside and the outside
    Faribault, MN
    Do you have a standard price for ceramic coating a 998 stock catalytic converter?
    Safe Rides,
    IBA 70020
    Sep 2015
    Awendaw, SC
    Can you give me a couple guestimates? One for coating the two header pipes and a cat delete on just the inside and another for both inside/outside? It's an 998cc 2014 Spyder RS se5
    Sep 2015
    Awendaw, SC
    Just got a PM from RLS stating that the coating is only on the outside of parts, not available on the inside , contradicting the post above
    Mar 2019
    Waxahachie TX
    $125
    to coat your primary
    Mar 2017
    Turn around time? or exchange?
    Mar 2019
    Waxahachie TX
    i have primary mufflers for all models send your in and i can ceramic coat it and or send one i already have coated out $125 exchange $300 if you want to buy one that has been coated contact me at rlsexhaust@yahoo.com or 469-878-5166
    Mar 2019
    Waxahachie TX
    2 week turn around if you have to have your original back .
    Mar 2019
    Waxahachie TX
    I still have not sold this service once so i guess it was not that good of an idea !
