Results 1 to 13 of 13
Thread: Shift Shudder
    Jun 2015
    Boise Idaho
    Default Shift Shudder
    Been a long winter and I cannot remember if this has been the case from day one.
    When I start the Spyder I let it warm for about 30 seconds to a minute while I put on the helmet and jacket and then when I shift into reverse or first and proceed to pull away it shudders almost like it is pulling against the brakes. After I have run for about 10 minutes it takes off smooth as butter. It is just those first few take offs from a stop.
    2014 STS SE5 with 8500 miles.
    Thanks for the replies.
    Tim
    Default Curious...🤔
    What oil and condition of it are you using. When did you change it last. Good place to start ...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jun 2015
    Boise Idaho
    Amsoil 10-40 last September
    Jun 2015
    Boise Idaho
    also only 600 miles ago so basically fresh
    May 2016
    Tombstone Az
    The centrifugal clutch is just cold. If it does it warm then it may be a few oz low on oil.
    Jun 2015
    Boise Idaho
    Was hoping it was something like that as the oil level is just below the upper limit mark on dipstick. When warm it is smooth on takeoff and gear to gear shifts.
    Nov 2015
    Chardon, OH
    Was probably the case since day 1. Identified in a tech bulletin. Normal.
    https://www.spyderlovers.com/forums/...ghlight=clutch
    Doug
    ”Freedom is not a loophole”
    Active Member ARNIE R's Avatar
    Mar 2017
    Leesburg, VA
    I just start mine up while I am putting on my riding gear and hooking up the phone and GPS. About 3 minutes and all is good.
    2014 ST-S Cognac
    2014 ST-S , OEM Yes Cognac
    Jun 2010
    Las Vegas
    Hi Tim! Haven’t seen you post in a long time, I hope everything is good with you.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Bossier LoUiSiAna
    Also check belt tension shudders if it slips too
    Apr 2014
    full time RV'er on the road. Well we were. Now, 6 months in ThreeRivers Mi and 6 months in Apache
    My 2013 has pretty much done the same thing on first start up IF I don't give it a fairly long warm up. Never seems to reoccur during the rest of the ride. I haven't been able to attribute it to lower than ideal oil levels. My view is that is the nature of the beast with cold oil. I have pretty much run the factory oil as I have it changed at a dealer.
    Aug 2008
    MA & NH
    I used to have that issue.
    Jul 2011
    Mitchell, Ontario, Canada
    Basically normal. Causes no harm so just ignore it and drive on. My 2013 STL did it from new until I traded it in 2018.
