Results 1 to 9 of 9
    Dec 2018
    ON
    Default Rear wheel bearings
    The F3 has 2 of the 6205 bearings. Are the RT's the same? BRP lists different part numbers but I suspect they are the same.
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    just curious why you would care? do you have a set of F3 bearings laying around and hoping you can use them, or....
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Dec 2018
    ON
    No...thats not it. My F3 had oem made in china bearings. I replaced them with NTN Bearing 6205ZZC3/EM Single Row Deep Groove Radial Ball Bearing, Electric Motor Quality. This 100% fixed the gear whine type noise that some are complaining about between 40-50mph (70-80kmph). I dont have an RT but have friends who are complaining of the same issue and want to know if they can use the same without taking wheel apart first. It is a more expensive bearing but is US made, quiet running and a lot more quality.
    Jul 2011
    Mitchell, Ontario, Canada
    All rear wheels 2008 to 2019, models GS, RS, ST, RT, F3 all use the same wheel bearings and seals. Even if BRPs part numbers change over time.
    True. Many times the only difference in a BRP part # change is the supplier. I suppose quality might also be a factor. But the point being, the specs. are the same and the parts completely interchangeable. It is a mistake to assume that if the part # changes, the new will not interchange or be a replacement for the old.
    Blue Springs, Mo
    A long time member of spyder ryders KC told me watch the tighting of the axle to tourqe when it comes to tire changes. Safe travels.
    USA
    Quote Originally Posted by dcarver View Post
    A little background would be nice. More torque, less torque? My spec is 155 to 177 Lb/Ft of torque. I tend to go on the lower end.
    h0gr1der
    USA
    Quote Originally Posted by rwill2cruz View Post
    Hey, I looked up that part number, it's a sheilded bearing, and I believe the Spyder uses double sealed. Is that correct?
    h0gr1der
    Dec 2018
    ON
    Yes. Works great. It is sealed bearing as well but not plastic seal
