Results 1 to 18 of 18
    May 2016
    Noblesville, Indiana
    Default New oil change video just posted on YouTube for the Ryker
    Check it out on YouTube. Looks super easy.
    Apr 2019
    Clinton, MS
    Apr 2019
    Kansas
    If that's the video it sure doesn't show a lot, but the process is in the owners manual anyway.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by RykerUSA View Post
    Can you link the video that you're talking about?
    May 2018
    MN
    Stupid questions, what is the easiest way to get hood released? Proper way to remove the right air intake to put in oil? Thanks for posting the video!
    Apr 2019
    Kansas
    Quote Originally Posted by nchangin View Post
    Take a look at your manual. There are 2 little tabs in the front of the hood underneath that you pull up and pull the hood straight out. All you have to do to put oil in is turn the tab on the right side where the CVT filter is and there it is.
    Mar 2019
    Depoe Bay Oregon
    The video at least shows the drain plugs, but there is a correct order to remove them. Also the manual say's 3.4 qts and not 3.7. Over filing can cause cavitation and let in air. The 2 bolts have torque values, maybe to make sure the crush gaskets set properly. I might change mine tomorrow if the weather is good, and I can stand to stay home for awhile. It is just way to much to fun to ride.
    May 2016
    I change my oil last week. It was extremely easy. Refill took exactly one gallon. Checked after a couple of different rides and oil is right at the full mark on the dipstick measured just after shutting off Engine.
    Nov 2018
    N.E. Ohio
    Same here took one gal. cueman
    Active Member bcraig's Avatar
    Apr 2019
    Grove City, OH USA
    was that one gallon on a 600 or 900? Was that one gallon with a new oil filter?
    May 2016
    900 with new filter
    Active Member vstrommer's Avatar
    Oct 2015
    miNNESota
    Quote Originally Posted by oregoncoast View Post
    Sooo what is the correct order for the oil change process?
    2019 900 Rally , Black
    Mar 2019
    Depoe Bay Oregon
    The manual says the 17mm first, if it makes any difference I don't know. I changed my oil yesterday and the bolts were almost loose, Also it did take more than the 3.4 qts than the manual says. But as others have said it is an easy job.Cost me about $35.00 with 5w- 40 oil from Amazon and filter kit from Baja Ron.
    Oct 2015
    miNNESota
    What oil brand did you go with?
    Mar 2019
    Depoe Bay Oregon
    Amazon has there own brand, don't know who makes it but it meets all the specs and $30 for 6 qts delivered. I used to go brand specific but no point paying more than you need too. I can already hear the grumbling.
    Aug 2015
    Crosby,Texas
    Default oil change kit
    Amazon sell a 3 1/2 qt. oil change kit. Not enough oil like RykerUSA and cueman said you need 4 qts.
    Mar 2019
    Depoe Bay Oregon
    Quote Originally Posted by KID Ryker View Post
    They might sell a kit but mine was 6 qt case, so I have 2 qts for the next oil change.
    Aug 2015
    Crosby,Texas
    Used 3.5 qts. plus 10 ozs. For my oil change.
