Results 1 to 4 of 4
    Active Member P.W.'s Avatar
    Mar 2018
    IA
    Default First mod.....cat delete?
    Today we just bought a 19 RTL and I would like to start with the mods already. When deleting the cat. is there anything I need to do to the ecm? I've read that if you let the engine idle for 15 min the ecm will change things on is own....Is this true? Or do I need to some kind of reflash or anything else?
    Thanks for your time and help!!
    P.W.
    MOgang Member Yazz's Avatar
    Nov 2009
    Cypress, Texas
    Quote Originally Posted by P.W. View Post
    P.W.
    Nothing to do to the ECM. Take the cat out, let the engine idle for around ten minutes to let the RTL computer reprogram.
    Joy
    Very Happy Ryder...
    '09 Phantom and a '15 F3-S
    If you don't slow down, they can't catch you..
    ​If you don't give up, they can't win.
    What a long strange journey its been.
    I've done a few now. The process is really Simple As! Remove the cat; install delete pipe; start & let engine idle for a while (I've been told 15 mins too, but probably only ever manage to last about 10 mins with no apparent ill effects - yeah, I know, I'm a tad impatient. ) Then go for a ryde! It probably does pay to start a little gently, then work back up to normal ryding over the next 20 miles or so, maybe even over that tank of gas' worth. But the ECM on any modern engine really is pretty smart, and with all the sensors engines have to allow them to run cleanly & economically, it usually won't take a whole lot of time for the ECM to re-learn & refine all the engine operation parameters it controls after such a relatively minor change as installing a variation to the exhaust gas flow.
    Now get out there & Ryde!
    Mar 2018
    IA
    Thanks for the heads up guy's!!!
    P.W.
